car shaking /rattling over 80MPH
i cant think of anything else it could be, balancing is the biggest cause of steering wheel vibration at high speeds oh... and a buckled alloy wheel or eneven air pressures in 4 tyres (should be about 30 all round)
start with checking the air pressures in the tyres as this is cheapest, if not the balance the wheels at a tyre place and if the wheel is buckled they will tell you this
good luck
i cant think of anything else it could be' date=' balancing is the biggest cause of steering wheel vibration at high speeds oh... and a buckled alloy wheel or eneven air pressures in 4 tyres (should be about 30 all round)
good luck
that might be a little high, think its 26 front and 24 rear on normal loads :)
good luck
oooops iv always stuck 32 all round :$
never had uneven wear though
i had this problem on a vr6 once that i had just bought and it turned out to be all the engine mounts were knackered at slow speeds upto 50 it was fine but has you went faster it got worse it could just be wheels but if you have them done and its still as bad i would look at mounts oh and it felt like car was going to vibrate to pieces scariest vr i ever drove changed mounts and was perfect.
