matth76 1 Posted November 5, 2005 Report Share Posted November 5, 2005 HiAre FK Highsport Coilover Kits good quality and do they give a very harsh hard ride or very comfortable ride... Ideally I want the comfort to be virtually the same as standard but obviously have my car with a much lower stance and much much less body roll when going round corners. FK also do Konigsport which are very good and fully adjustable but these are a bit too expensive so am interested in finding out more about the FK Highsport coilovers. Does anyone have highsport ones and in what way are they adjustable - is it just the ride height and if so how easy is it to adjust the height?Is it true FK Highsport coilovers have Koni shocks? Also, would new coilovers take longer to fit by a garage than new springs and shocks?Thanks for any info.Matt Link to post Share on other sites
stockers 1 Posted November 6, 2005 Report Share Posted November 6, 2005 i'll let you know in a couple of weeks when mine get fitted Link to post Share on other sites
Eat this 2 Posted November 6, 2005 Report Share Posted November 6, 2005 mine has these and i like it not too hard but handle really well with the right tyres on Link to post Share on other sites
apd 0 Posted November 6, 2005 Report Share Posted November 6, 2005 had a vr with standard suspension-poor handling.got one with koni coilovers,eibach roll bars and VT mounts.ride is rock solid.comfy and yet direct with NO pitch and roll. Link to post Share on other sites
binliner 0 Posted November 6, 2005 Report Share Posted November 6, 2005 To answer your questions...They are pretty comfortable, obviously not like standard shocks but not too harsh... They handle pretty well but if anything they are a bit soft for my liking. Having had both I'd say go for konigsports everytime, they are worth the extra.Ride height adjustable only and it's easy enough to adjustNo Highsports dont have koni shocks... konigsports doCoilovers wont take any longer than fitting shocks n springs. Link to post Share on other sites
MrBen 0 Posted November 6, 2005 Report Share Posted November 6, 2005 I've just ordered a set of Konigsports to replace my ageing Koni shocks/Eibach spring set up. I have driven VR's with both Highsports and Konigsports, and found the Highsports to be a bit bouncy, where the Konigsports give much better body control, presumably due to the better quality Koni damping.For an additional Link to post Share on other sites
matth76 1 Posted November 6, 2005 Author Report Share Posted November 6, 2005 Thanks for your help guys. Looks like Konigsport are the better ones to go for and I assume they will last quite a few years..will the FK (Highsport or Konigsport) coilovers last much longer than standard shocks and springs? So are Highsport much better than standard suspension or just a little bit...whereas the Konigsport are far better? In what way are they much better than Highsport ones?I've had a look at the Venom Motorsport site and they offer the FK Konigsport coilovers for Link to post Share on other sites
MrBen 0 Posted November 6, 2005 Report Share Posted November 6, 2005 I'd doubt they'd last much longer than standard - most standard shocks and springs will last 100,000 miles easy, whereas the Koni shocks on mine are about 60,000 miles old and utterly knackered - but they have a much harder life due to the reduced travel on a lowered car etc.Depends what you mean by 'better' really. The Highsports are not damping adjustable, only height adjustable, so the damping gets stiffer as you lower the car, whereas the Konigsports are fully adjustable, so you can adjust the damping to your preference. Link to post Share on other sites
matth76 1 Posted November 6, 2005 Author Report Share Posted November 6, 2005 If the car is lowered say 40mm on the fk Highsport fixed damper coilovers would the ride be roughly the same as standard or extremely hard? There was a mention above that the Highsport are much 'bouncier' than the Konigsport which I guess means the cornering will be far less stable. I'm considering fk Konigsport as the ones to go for as once the choice has been made that's it... and for just Link to post Share on other sites
matth76 1 Posted November 7, 2005 Author Report Share Posted November 7, 2005 Would FK Highsport coilovers be better than separate 30mm lowering springs and uprated shocks for example Koni shocks and H&R springs? The FK Highsport coilovers are height adjustable only with fixed damper rates. Stealth have quoted me Link to post Share on other sites
apd 0 Posted November 7, 2005 Report Share Posted November 7, 2005 ask STEALTH to recommend the best set up money can buy?vince's reputation is first class. Link to post Share on other sites
binliner 0 Posted November 7, 2005 Report Share Posted November 7, 2005 Koni shocks & H&R (or eibach) springs will handle better than highsport coilovers and are damping adjustable (but not height) FK Konigsport coilovers are more versatile in that they have similar handling but adjustable ride height Link to post Share on other sites
MrBen 0 Posted November 7, 2005 Report Share Posted November 7, 2005 I want to eliminate body roll and wallowing round corners as much as possible but I also want a nice comfortable ride.. ideally the same comfort or similar to the standard suspension. I don't think that's really feasible! Anything which helps eliminate body roll etc is going to reduce the ride quality! Link to post Share on other sites
matth76 1 Posted November 7, 2005 Author Report Share Posted November 7, 2005 Yeah you're right... I do assume it will be harder and definitely stiffer in some respect (but there is "harder" and then there's very hard...my last car had lowered suspension by just an inch but was bl**dy awful) but I want it to be stiffer and much more controllable round corners without being too bouncy yet to still be relatively comfortable without loosing any teeth. Anything that comes close to the suspension of a civic type r would be nice! (a bit too hopeful!)So if 30mm H&R lowering springs and Koni shocks (I assume these will not be adjustable damping) are better than Highsport coilovers... how do they compare to FK Konigsport coilovers? Link to post Share on other sites
binliner 0 Posted November 7, 2005 Report Share Posted November 7, 2005 if u want comfort with less body roll then get uprated anti roll barsand koni do damping adjustable shocks Link to post Share on other sites
Baz 0 Posted September 17, 2011 Report Share Posted September 17, 2011 Errrrrr ? Link to post Share on other sites
b road blaster 0 Posted September 18, 2011 Report Share Posted September 18, 2011 i had the fk coilovers fitted on my astra turbo and the bloody things was so hard it was stupid ok for a nice smooth track but for road use they were a joke.just used to crash from one bump to the next. Link to post Share on other sites
