veedubnutz 0 Posted October 21, 2005 Report Share Posted October 21, 2005 Alright chaps. Got a bit of an odd problem with my vr6. For some reason when i set off from a standstill, more often on a hill(when the engines under load) I get a kinda low pitched squeaking? Sounds like something slipping from the gearbox side.... although I cant be sure its that side. Its kind of irritating as you can imagine. Oh FYI it also sometimes does it on gearing down? Any ideas? This ones definitely on for the hardcore VR6 nutters out there! !amazed Link to post Share on other sites
Craig 0 Posted October 21, 2005 Report Share Posted October 21, 2005 Engine mount? Link to post Share on other sites
silverline 0 Posted October 21, 2005 Report Share Posted October 21, 2005 clutch release bearing? Link to post Share on other sites
Justicevr6 0 Posted October 21, 2005 Report Share Posted October 21, 2005 I agree with silverline cutch release bearing. Link to post Share on other sites
Craig 0 Posted October 21, 2005 Report Share Posted October 21, 2005 Surely you would hear a squeak from a worn out clutch release bearing every time the clutch was used? Link to post Share on other sites
veedubnutz 0 Posted October 21, 2005 Author Report Share Posted October 21, 2005 It doesnt do it while i am pulling the clutch up normally, only under load. Would an engine mount make a continouous noise? Link to post Share on other sites
silverline 0 Posted October 21, 2005 Report Share Posted October 21, 2005 if your pulling away under load you'll be using more power than normal therefore putting more load on the release bearing. Link to post Share on other sites
veedubnutz 0 Posted October 23, 2005 Author Report Share Posted October 23, 2005 Also, im not sure if this is related, but after a long stint of not using the clutch(ie on a motorway) , when I use the clutch it feels really heavy. then after a couple of uses, it lightens up again? Link to post Share on other sites
veedubnutz 0 Posted October 24, 2005 Author Report Share Posted October 24, 2005 Anybody else got any views on this? Link to post Share on other sites
VR6Pete 1,455 Posted October 24, 2005 Report Share Posted October 24, 2005 My clutch sqeek's but that's because my clutch slave cylinder has seen better days. Link to post Share on other sites
dubloke 4 Posted October 24, 2005 Report Share Posted October 24, 2005 Also' date=' im not sure if this is related, but after a long stint of not using the clutch(ie on a motorway) , when I use the clutch it feels really heavy. then after a couple of uses, it lightens up again?[/quote']that'll be because its hydraulic and operating it often makes the fluid more viscous as it uses the same resevoir as the brakes, not often used on the m/way either! Link to post Share on other sites
