camber and toe are adjustable on golfs...
camber is adjusted by loosening the shock to hub bolts then repositioning it, then tightneing the bolts.
toe is adjustable with the tie rods, as are most cars.
most places don't have the equiptment to adjust camber unfortuantly.
i've increased my camber massively, to a suspected approx 2 degs neg...wasn't done scientifically, but i lucked in and it's a dream...lot less steering effort required, car is nice and responsive, with a touch of mid corner oversteer. please note, this is quite extreme, most peeps would prob be happier with 1 to 1.5 degs of negative camber. i believe the factory set up is 0.5 degs, which isn't enough IMO as i would destroy the outside of my tyres.
i believe zero toe is best too, but am unsure about mine as i've never altered it, so i have whatever the factory recommends.
Thanks loads for that. Ive had the tracking/camber done before, just didnt ask about the toe. but i had some wheel to curb action recently and i think ive bent something. so im gonna get it all alligned again and see if it all falls outta place after a while. the place i took it to done the camber but not toe though. dunno why.
[ Edited Sat Apr 10 2004, 11:19PM ]
zero i think. not sure. with it being dropped about 80mm they didnt know what to do, weather to put it to factory or tweek it a little. i might get it set about 1 degree negative next time. but ive been driving with it set as far negative as it will go, cos i bumped her, n didnt know how to set it till recently. so now ma damn tires got 3 rings worn around it from ma coilovers. gggrrr. there £75 gone... i jus want ma toe sorted, cos the car feels like its pulling left and right as i hit potholes, its pissin me off, lol.
Set the toe to 0.0, as it alters when driving to the correct setting (which obviously cant be set stationary)
As for camber, set to standard, unless you have deep pockets for tyre replacement. It will chew the inner edge up quiker than roadrunner with his arse on fire..
Or you are using as a track car, when tyre wear isnt that important. :)
As for camber' date=' set to standard, unless you have deep pockets for tyre replacement. It will chew the inner edge up quiker than roadrunner with his arse on fire..
thats not ture...i run about two degrees, and wear the tyre completely evenly (only road driving). when i has standard camber i used to destroy the outside of the tyre.
in fact, its excessive toe that usually kills the tyre, not camber.
Before you go getting it set up again, make sure your bushes, bearings, tyre depths and pressures are in top condition, (these play a major part of incorrect setting!)
VW specify that you have a full tank of fuel, full washer bottle, corner to corner is level and the tool kit is in the boot?! Nothing else to be in the car.... anything else like subs have to acounted for..... ;)
but (if I read your earlier post correctly) you don't actually know exactly what your camber setting is, so its not really safe to say that a -2 camber won't wear tyres unevenly :|
thanks for the advice peeps, i knocked my wheel and threw the camber aout a load, and when i took it to get it reset, the guy said i could only adjust it 2 degrees, but it was 4.2 degrees negative, ha ha. so i think ive bent something anyway. i curbed it again in the snow, and it seemed to go back and now after a little play myself not on a bisbarth, it seems to be fine, so im prons gonna replace the wishbones, and maybe put a new arb on there and get it set again, guess its not worth going performance arb's with coilovers as ive seen in many other posts, ill weigh up the cost tho. thanks again.
If you have knocked you hubs in as much as poss. on OE shocks, that may be more than 2 deg.
Depends on the position of the bottom ball joints ect... unless measured they wont be equal.
And if you run to much negative cam. you WILL run the inner edge down quicker than standard settings, and scrub if the toe is out..
ACF you might like to know that when you change the wheels from standard fit to a different ET, then the pressure points and weight distributionand forces change, so cause different tyre wear patterns
It isn`t as simple as just pushing the hub in as far as poss, and as for someone `who knows who they`re talking about` i tend to do this for a living, `beizbath` ect, and have recently return`d from the VW training center in milton keyn`s, on a refresher course for wheel alignment... phew!!! 8o)
any how, VR monster, just to be on the safe side have you checked that you havent damaged anything else? :(
nah, im not too sure if anything is damaged, i had my car into my friends garage, and he said theres nothing wrong, but when he went to get the camber ect... set up he couldnt get it on the ramps ha ha. i cant see any damage but would bending the anti roll bar or wishbone alter the camber at all, or is there anything else that would if damaged. also, i knocked the inside of the wheel when i curbed it (tight bend, hit the grass and a pincurb in the middle of nowhere.) so it sent the top of the wheel in towards the inner arch, if that sheds any light on my situation. so i had the hub pulled outover as far as poss and it was still visably out, altho, it looks fine now. thanks again.
It would also take a hell of a thump to bend a arb, and it shouldnt affect alignment.
Like acf says, check your wishbones carefully.. they dont take a lot to bend. Look carefully at your subframe too, iv`e seen a couple of them bent before.
In a previous life i once bent a hub when i hit a curb at warp speed, that was quite hard to notice. It only showed up when i put it against another and noticed the difference
well im replacing the wishbones anyhow, and my friend checked the shock as i asked him to ensure it wasnt damaged during the mot work i had done. dont fancy messing on with the hub, but im removing my front suspension next week for some tomfoolery, so ill probs do it all then. yas have been great on this one.
