brans 4 Posted August 14, 2016 Report Share Posted August 14, 2016 I have an 01 Jetta GLX VR6 AFP and I was wondering if this is even worth boosting? I know there's better vr6's I can do this to but I just want to learn and get to know the anatomy of the VR6 Link to post Share on other sites
RBPE 199 Posted August 25, 2016 Report Share Posted August 25, 2016 (edited) What do you mean "better VR6's"? I take it that it is a mk4 based 12V? Like the ones we didn't get here? If so, then it uses ME7.1. ecu so is better than older Motronic M based ones as it is more advanced, probably more tuning info on the net too. As a vague reply.........ALL VR6's are worth boosting! Personal taste is personal taste though! Edited August 25, 2016 by RBPE VR6Pete 1 Link to post Share on other sites
brans 4 Posted September 1, 2016 Author Report Share Posted September 1, 2016 Well is there a favored engine code?@RBPE Link to post Share on other sites
RBPE 199 Posted September 1, 2016 Report Share Posted September 1, 2016 As we didn't get the mk4 12V in the UK then I don't know the differences between the models/ecu's but at a guess I would assume they are similar to the early 24v's with inlet only VVT. As such, you may be able to use a 24v early engine without major ecu mods but the later models have dual vvt. In the US the dual VVT engine is the BDF and apart from the obvious differences with displacement etc, the ecu's and set up's of the engine are very similar to the R32 mk4's. So an early inlet only one might work with your ecu but you'd need to make some changes with a newer dual vvt one as a very rough guess from someone in a different market! In short, just boost the engine you've got, all 12v/24v will provide massive power if your wallet is deep enough, save money on changing engine etc and use it on turbo/engine strengthening! Link to post Share on other sites
RBPE 199 Posted September 1, 2016 Report Share Posted September 1, 2016 (edited) p.s. why not to piddle about changing engines and spend it in other areas; Edited September 1, 2016 by RBPE blackwookie 1 Link to post Share on other sites
blackwookie 26 Posted May 13, 2017 Report Share Posted May 13, 2017 Is that an afp engine code? I aparently underestimate my valve train. Thats a lot of power for stock head Link to post Share on other sites
