1 minute ago, FASTEDDIE4321 said:
Clutch is fine, it switches gears easily.  I don't know if enough fuel is getting through because it accelerates slowly.
Ok, switching gears doesn't mean good clutch. From what your saying is you change gear the revs rise quicker than normal and you don't accelerate as quick as normal? If you weren't getting enough fuel your revs wouldn't rise at all and you would jerk and misfire?
