RBPE 199 Posted October 5, 2015 Report Share Posted October 5, 2015 Thanks for the feedback guys, I'm driving it every day since I finished it and have experienced no problems. I'll be interested to see how the intercooler stacks up, was looking at them for some of the lower powered builds but thought they might be a bit small for the flow these cars can generate. We've got a similar one that is longer and a bit thicker but is twice as much as those - keep us in the loop on it mate! Link to post Share on other sites
Carlmoore 0 Posted January 28, 2016 Report Share Posted January 28, 2016 hi everyone just read this thread i own a 01 4motion is there kits available to but to turbo charge it and getting it fitted ?? what sort of price would i be looking at ?? thanks in advance guys Link to post Share on other sites
cicciovr6 0 Posted March 24, 2016 Report Share Posted March 24, 2016 Mo much hp have you got now? Link to post Share on other sites
dave_424 48 Posted March 25, 2016 Author Report Share Posted March 25, 2016 10 hours ago, cicciovr6 said: Mo much hp have you got now? I haven't had it on a rolling road yet, but it's expected to be 400+ bhp at the crank. Not sure of the amount of drivetrain loss through the 4wd system Link to post Share on other sites
cicciovr6 0 Posted March 25, 2016 Report Share Posted March 25, 2016 Wow..But about gt3582r..i've see that there are 3 models on garrett website..what is your turbo? Which ar? Which trim? Link to post Share on other sites
dave_424 48 Posted March 26, 2016 Author Report Share Posted March 26, 2016 I too found there too many options for the gt3582r so I phoned up turbo dynamics to order. It's a . 82 exhaust housing, t3 flange and 4.bolt exhaust outlet (ideally I would have liked v-band) also a 4" compressor inlet Link to post Share on other sites
cicciovr6 0 Posted March 26, 2016 Report Share Posted March 26, 2016 And about spool? What is turbo range? How many psi at max boost? Link to post Share on other sites
dave_424 48 Posted March 27, 2016 Author Report Share Posted March 27, 2016 Starts building boost a bit above 2000rpm and full boost at 3000. Max boost is whatever you have the system set at. Link to post Share on other sites
cicciovr6 0 Posted March 27, 2016 Report Share Posted March 27, 2016 Have you got a video of The tacho? Link to post Share on other sites
dave_424 48 Posted March 28, 2016 Author Report Share Posted March 28, 2016 Here boost was about 12-13 psi Link to post Share on other sites
cicciovr6 0 Posted March 28, 2016 Report Share Posted March 28, 2016 Thanks...but your max boost is always 12-13psi? Or have you tried to get more boost? Link to post Share on other sites
dave_424 48 Posted March 28, 2016 Author Report Share Posted March 28, 2016 I'm not sure you understand how turbo boost works. Boost is what you set it to, and will stay at that psi. Unless you want more power, then you can turn it up. Because I'm on standard pistons and conrods I don't want to push the power too high so have set my boost level to around 15psi to be safe. I have run over 20 briefly. Also using the plastic intake manifold so dont want that to break. If I wanted to I could turn it up to 30psi but things would start to go bang. Link to post Share on other sites
cicciovr6 0 Posted March 28, 2016 Report Share Posted March 28, 2016 I ask this to know how much boost stock rods/pistons can handle in safety mode... So my question is: what is the max boost with stock hardware? ( but with a head spacer) Link to post Share on other sites
dave_424 48 Posted March 28, 2016 Author Report Share Posted March 28, 2016 It's generally accepted that 15psi is safe with a GT35 turbo, can possibly push it to 20. That's with head spacer, ARP rod bolts, ARP head studs and a very good tune. RBPE 1 Link to post Share on other sites
cicciovr6 0 Posted March 28, 2016 Report Share Posted March 28, 2016 I'm thinking to driving safety whit 10psi, but in race mode whit 18psi.. So for compression ratio what is the best choise? 9:1 or 8.5:1? Link to post Share on other sites
vr6downsouth 0 Posted July 26, 2016 Report Share Posted July 26, 2016 Awesome build mate. Where did you source your r36 rod bearings from? Link to post Share on other sites
dave_424 48 Posted July 26, 2016 Author Report Share Posted July 26, 2016 Thanks, phoned up TPS with the part numbers Link to post Share on other sites
doubas 0 Posted January 1, 2018 Report Share Posted January 1, 2018 Hello there, This is my first post in this forum which am proud to be part of!!! Sorry for posting on an old thread, but would like very much to know what you did for clearance of the downpipe, I could barely fit a 2.5" which have like 5mm from the 4motion propshaft rubber ring and the body? do you have any pic ? Link to post Share on other sites
Goodge123 5 Posted January 2, 2018 Report Share Posted January 2, 2018 How does the car feel mapping wise ? Trying to work out if I should get it live mapped at stealth or send the ecu to the phirm with my spec of parts Link to post Share on other sites
Nommh 0 Posted April 19, 2022 Report Share Posted April 19, 2022 Hi idk if ull still see this but do I need a longer timming chain then Link to post Share on other sites
