VR6Pete 1,455 Posted June 4, 2005 Report Share Posted June 4, 2005 What is the correct procedure for removing and fitting a new clutch slave cylinder on a OBD2 VR6?Pete Link to post Share on other sites
badboyV6 4 Posted June 4, 2005 Report Share Posted June 4, 2005 Hav e you looked in the bentley manual Pete? I dunno spend all that money and recommend the thing and you never use it! ;-) :-D Link to post Share on other sites
Eat this 2 Posted June 4, 2005 Report Share Posted June 4, 2005 hehe Link to post Share on other sites
acf8181 0 Posted June 4, 2005 Report Share Posted June 4, 2005 well, its held to the 'box by two 13mm bolts, and the hose is attached to it with a 10mm i think.....just simply swap it over...then bleed the thing (must use an easi bleed) Link to post Share on other sites
VRmonster 1 Posted June 7, 2005 Report Share Posted June 7, 2005 just avoid moving the piston in the cylinder as it may break the seals. hapens to most of vw cylinders as theyre designed with too much play and loads of dirt gets dragged in. just about to remove mine if you want a few pics pete. although im not taking the hydraulic pipe off as im just taking my box out. doesnt need to come all the way off, just moving out of the way. Link to post Share on other sites
