This is a very old kit I've had for like nearly 9-10 years
These days company's use a sure flow pump or whatever it's called
The plug is to power it live earth and another Earth to turn it on and off
Same pump used by the old rally cars but they used 2 side by side
Ah I see, and by using his system does it help with the oily residue in the throttle body?
Only really when I use pure methnol
At the moment only get it out to use couple days befor an oil change
It's not on the car fixed permanently yet
If you want to try it get a spray bottle filled with water
If you need any help his a shout mate
Would maybe try it one day, I'm in middle of turboing mine but might look into that when it's done :D
I'd get a kit from devilsown with 2 jets with one before the turbo and other just after intercooler
The pre turbo will drop Inlet temps and lowers the pressure difference before and after intercooler
Normally after the intercooler you lose couple psi as the air is abit cooler
