Joe M 0 Posted May 13, 2005 Report Share Posted May 13, 2005 If you want a 6speed then go for the gemini kit from Stealth, bit more expensive than quaife but worth it. Probably about 3k though if you go for that with a diff.Getting my gearbox removed, rebuilt with quaife, new clutch and refitted came to about 1400. Changing the final drive would add about 200, id probably go for a lightened flywheel and uprated clutch as well if I got it done again, that and changing the 5th cog for a slightly longer one and it would probably be near enough spot on 2 grand. Link to post Share on other sites
VR6Pete 1,455 Posted May 15, 2005 Author Report Share Posted May 15, 2005 contacted stealth, they dont do gemini anymore, stealth quoted about 1.7k for the 6 speed and then I'd probably source my own peloquin diff and flywheel. it's already got a brand spanker cluth in it from when i had the chains/head done... Link to post Share on other sites
VRmonster 1 Posted May 15, 2005 Report Share Posted May 15, 2005 sounds liek a fair price for 6 speed. ill get in touch with my contact concerning the peloquin and get some definate prices. Link to post Share on other sites
VR6Pete 1,455 Posted May 15, 2005 Author Report Share Posted May 15, 2005 cheers. I'm now after a O.E gearbox to get built up. Link to post Share on other sites
FishWick 21 Posted May 17, 2005 Report Share Posted May 17, 2005 Speak to Vince, he's got a ratio program on his computer but using a G60 3.61 diff, 5th at 4000rpm, drops to 88mph. I think it's about 95 normally? So it's not a drastic drop by any means, but the improved ingear flexibility will be welcomed.Mine's booked in for a rebuild + 3.61 diff + Quaife ATB in a week or so. I think he's thin on the ground of 3.6 crown wheels, so if you want this mod, book it soon otherwise a new crown from VW will cost you a chunky £200.If you want more flexibility from the engine in gear, but want to keep the same 5th's relaxed cruising, you can fit a taller 5th.The 02A does whine a bit though, but it shouldn't be THAT noticable.[ Edited Tue May 17 2005, 11:02AM ] Link to post Share on other sites
VR6Pete 1,455 Posted May 17, 2005 Author Report Share Posted May 17, 2005 I'll discuss it with Vince when i'm up there on 27th... Link to post Share on other sites
