Hello lads & ladies I'm after some advice - symptoms first - golf vr6 97 running erratic revs up and down sounds like a tank even when warmed up quite smokey off whiteish colour strong smell of petrol.
Little story to go with it - the car has been garaged for a while decided to get her ready for the summer, running fine all it needed was an exhaust and wheel bearings all round so off to my local vr6 'specialist' i sourced a decent exhaust and he got the bearings, so I got a phone call a week later saying it needed a coil pack which I got and gave to him and two weeks later I went to collect my vr (£500) it was running a little ruff he said its because there was no petrol in it so I put some in and drove straight home as it needs camber and tracking done due to new bearings which I planned on doing yesterday but I turned over and got the above symptoms ( it's had a new rad, temp sensor, stat and stat housing all fitted myself ).
What can my problem be, I know I can take it back and demand it be sorted but to be honest I'm fed up with dodgy mechanics and the 'could be this could be that gimme more money and I'll try something else' approach.
Cheers guys
Sounds like it could need a new MAF mate. Try disconnecting it and see how it runs then. Won't be prefect but should run smoother if that's the issue. Certainly should show if that's the problem. Smoking could be something else altogether, is it using any water?
Sent from my iPad using Tapatalk
Could it be blowing badly, I changed my exhaust and in nov and noticed it blowing slightly a few weeks later, my cars been off the road for a few months and when I fired her up mine sounded a bit rough, not had the chance to look properly as I've got a few jobs to do first but my first thoughts were that the blowing may have got worse, hoping it's nothing more when I look at it properly lol
Na mine doesn't really to be honest, I just quickly put it down to that quickly as my engine was running fine last time I fired her up and the only problem I knew about was the blowing exhaust and after reading that you recently changed your cat back put 2 and 2 together, hopefully the outcomes 4 lol
