Hutch 14 Posted November 29, 2013 Report Share Posted November 29, 2013 Hi, I was tracing a speaker fault and undid the twist-on/off modular connector for the NSR door. There were broken speaker wires in it, so problem sorted, but now I can't get the connector back on. I'm a fairly careful patient person - honest guv! - but after 45 mins trying I'm about to get a big hammer. Any advice or reattaching the plug? The problem seems to be that the part in the frame moves when I try to twist the bezel to do the other side up. Wonder if some silicon spray might help loosen things? Help :/ please. Link to post Share on other sites
CALICO 130 Posted November 30, 2013 Report Share Posted November 30, 2013 Make sure the outer bit that turns is in the correct position for the connectors to slide into each other before twisting. VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted November 30, 2013 Report Share Posted November 30, 2013 Good call Link to post Share on other sites
Hutch 14 Posted December 7, 2013 Author Report Share Posted December 7, 2013 About 20 attempts later! In the end I had to remove vacuum tube, gently press connector home, pray, dance, invoke things, and it made contact. Not easy! Then push vacuum tube in after. *sigh* Hutch 1 Link to post Share on other sites
