rsweeney 40 Posted March 23, 2012 Report Share Posted March 23, 2012 vr6 has been sat for a few weeks whilst waiting for parts.started vr after changing tensioner pulley and suddenly battery light has just come on. let it run for a while and still its on,. tried anpother good battery in it which is basically new and its still on.any ideas? Link to post Share on other sites
rsweeney 40 Posted March 23, 2012 Author Report Share Posted March 23, 2012 the idle is also slightly high now at 1000rpm if this is related Link to post Share on other sites
cabrioman 6 Posted March 23, 2012 Report Share Posted March 23, 2012 what`s the charging rate of the alternator should be around the 14v mark .... Link to post Share on other sites
rsweeney 40 Posted March 23, 2012 Author Report Share Posted March 23, 2012 havent checked that but will do tomorrow as its down garage for me to change suspension and check a few bits before its garage report Link to post Share on other sites
russj249 2 Posted March 23, 2012 Report Share Posted March 23, 2012 Have you knocked the plug off the back of the alternator by accident while changing belt and pulley? or is the little wire that goes to it split.anywhere.As Tony said above, battery light on dash means its not charging so get that checked, and also again as Tony said, i would expect between 14.2 and 14.6v charge from a good alternator. Link to post Share on other sites
kezwaldo 0 Posted March 23, 2012 Report Share Posted March 23, 2012 anytime ive had this problem with not just a vw any car its been the alternator "! Link to post Share on other sites
rsweeney 40 Posted March 23, 2012 Author Report Share Posted March 23, 2012 ok will look at that but would it explain slightly high idle ? Link to post Share on other sites
rsweeney 40 Posted March 23, 2012 Author Report Share Posted March 23, 2012 double post Link to post Share on other sites
oldmandon 1 Posted March 24, 2012 Report Share Posted March 24, 2012 Tensioner and belt shouldn't affect the tick over, it may just be coincidental from where it's been stood a while, as if the choke was on. probably settle if you give it a run.Battery light defo to do with alternator and belt. Is the belt correctly tensioned? As already mentioned, is the block connector at the back of the alternator in correctly? Link to post Share on other sites
oldmandon 1 Posted March 24, 2012 Report Share Posted March 24, 2012 Sorry forgot to say,Also with the tick over, the the tps out of the throttle body and give it a blast with electrical cleaner or WD40 type spray just incase some moisture has got inside giving a false reading Link to post Share on other sites
oldmandon 1 Posted March 24, 2012 Report Share Posted March 24, 2012 Take the fps out it should say...Have you managed to have a look at this yet. Be interested to know what it was Link to post Share on other sites
rsweeney 40 Posted March 24, 2012 Author Report Share Posted March 24, 2012 yeah plugged it in at garage and the alternator isnt kicking much out atall so definately alternator issuegetting one from paul on here so should be all good soon Link to post Share on other sites
oldmandon 1 Posted March 25, 2012 Report Share Posted March 25, 2012 Good to here that it's something easy to fix. Always a worry when it's an electrical issue!!!! Link to post Share on other sites
