MrP 0 Posted March 11, 2012 Report Share Posted March 11, 2012 VR6 passed MOT this week which I was chuffed about, but two days after the ABS light came on but with no other problems. Today I put my foot on the break and got a grinding noise from the wheel and vibration on the pedal. Kept coming and going.Any ideas before i start poking about? Just done a quick search on here and there's loads about ABS sensors but I'm guessing it's a bit more!! Link to post Share on other sites
russj249 2 Posted March 11, 2012 Report Share Posted March 11, 2012 Nope.. probably a sensor..My sensor has gone on mine, the hard vibrating pedal is just the ABS pump pulsing the system to stop the wheels from skidding. Basically because you have a dodgy sensor, it thinks one of the wheels is locked, so puts ABS on. You would also get it when pulling away or even just driving straight, this is most likely the traction control side of the ABS kicking in.You will need to get it plugged in to see which sensor it is. Before you change the sensor, make sure that all the teeth on the pick-up ring are all intact with no damage. Link to post Share on other sites
MrP 0 Posted March 12, 2012 Author Report Share Posted March 12, 2012 Fantastic advice, thanks. Don't suppose there is any way of turning off the ABS until i can get it plugged in? Link to post Share on other sites
lee123d 0 Posted March 14, 2012 Report Share Posted March 14, 2012 nope just pull the plastic bit in the dash and unplug it till uve done it Link to post Share on other sites
MrP 0 Posted March 14, 2012 Author Report Share Posted March 14, 2012 Is it worth replacing all the sensors to be on the safe side? Link to post Share on other sites
russj249 2 Posted March 14, 2012 Report Share Posted March 14, 2012 Don't really make a difference really.. just might be a little expensive to do all of then just for the sake of 1 playing up.You could also pull the ABS relay out to disable it, can't remember which number it is though. Link to post Share on other sites
BADOIR 2 Posted March 15, 2012 Report Share Posted March 15, 2012 price the parts at VWStealers , it,ll make your eyes bleed, £110,rear sensor...£66, front, and wait for it ..................................£800. for a fu**in pump had theconversation with em today... :@ Link to post Share on other sites
eastwood john 1 Posted March 15, 2012 Report Share Posted March 15, 2012 the`ve also got a stupid price for spark plugs, (6) Link to post Share on other sites
CALICO 130 Posted March 15, 2012 Report Share Posted March 15, 2012 My abs pump removed sent off and repaired will be costing me £545 very shortly but i had a knackered rear sensor abs did not cut in when not needed. I have been advised to always buy genuine sensors my pattern ones were plastic bodied genuine ones are metal And Expensive . Link to post Share on other sites
ssaunders 199 Posted March 16, 2012 Report Share Posted March 16, 2012 Hi, £545 seems steep, had my repair done by BBA remanhttp://www.bba-reman.com/catalogue/Product.aspx?product=3639plus a few hours labour, its been good as gold for 18 months.hope this is of use.S. Link to post Share on other sites
MrP 0 Posted March 16, 2012 Author Report Share Posted March 16, 2012 Think i'll price up new sensors this weekend at GSF. Haven't had any problems for two days but i'm sure it will be back! Link to post Share on other sites
filtee 0 Posted March 16, 2012 Report Share Posted March 16, 2012 Why spend hundreds getting them repaired when you can buy used ones for less than 50quid??? Link to post Share on other sites
CALICO 130 Posted March 16, 2012 Report Share Posted March 16, 2012 Hi' date=' £545 seems steep, had my repair done by BBA remanhttp://www.bba-reman.com/catalogue/Product.aspx?product=3639plus a few hours labour, its been good as gold for 18 months.hope this is of use.S.[/quote']Guess £545 is cheap then as its £475 exchange and my price includes removal and refitting and rebleed. Link to post Share on other sites
MarkVRsix 0 Posted March 19, 2012 Report Share Posted March 19, 2012 Second vote for BBA. They fixed mine for £100+VAT Link to post Share on other sites
MrP 0 Posted May 2, 2012 Author Report Share Posted May 2, 2012 Ok, it's been a while but i've got myself one of these fault code readers of eBay. The ABS hasn't made the grinding noise for a few weeks but the light is now on constantly. I've plugged the diagnostic in and it came back with no codes! Any other way of working out which sensor has gone? Link to post Share on other sites
MrP 0 Posted May 19, 2012 Author Report Share Posted May 19, 2012 Any ideas? Touch wood car is driving fine but light is still on. Link to post Share on other sites
CALICO 130 Posted May 19, 2012 Report Share Posted May 19, 2012 Get it vag-com'd eBay code readers clearly don't work if it's the pump it would flag up offside rear sensor. Link to post Share on other sites
russj249 2 Posted May 19, 2012 Report Share Posted May 19, 2012 I would have been able to help, but I don't have vag com anymore had it on an old laptop which broke so I just binned it! I'm only up the road from you in Kingswinford. There's a dyno place in wombourne that has a new version of VCDS.. I'm sure he'd chuck it on for you and tell you. The company is called Performance Torque, and specialise in VW Audi stuff. Have a word with Wil, they're numbers on their website. Link to post Share on other sites
