Geastb 0 Posted March 3, 2005 Report Share Posted March 3, 2005 I have a ZR2 charger and I need ALL the plastic/rubber pipes that join the s/c to the air filter and s/c to the throttle body - can some give me the sizes i need to order and where i can get them? I currently have the original carbon fibre connectors and i want to change these for some nice shiney s/s items - where can i get them? If anyone has a spare 6psi (istributor) chip they want to get rid of please let me know! Apologys if this is in the wrong section! :? Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 if you're using stainless elbows to replace the carbon ones then you just need to measure the silicone hose you already have and order new ones from SFS or a samco distributorhttp://www.sfsperformance.co.uk/http://www.samcosport.com/ Link to post Share on other sites
Geastb 0 Posted March 3, 2005 Author Report Share Posted March 3, 2005 I haven't got ANY silicon hoses - that's the problem - i don't know what size to order! Is it worth replacing the carbon fibre bends? Would s/s be better or are they just for show?Where is the cheapest/best place to get stainless tubing?[ Edited Thu Mar 03 2005, 12:20PM ] Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 s/s wouldnt be any different... you can measure the external diameter of your carbon elbows/maf/charger outlet and thats the diameter silicone you need... they are literally just connecting hoses about 100mm long (I can measure the length later but cant be arsed to take them off to do the diameter!) Link to post Share on other sites
mightyvr6 0 Posted March 3, 2005 Report Share Posted March 3, 2005 The inlet size is 80mm so you'd need 2 x 90 deg. 80mm elbows and 1 x 80mm - (whatever the outlet size is) reducer- possibly a 45 deg. elbow.Then you would have to drill a hole in each 90 elbow and insert a straight 90 deg. plastic connector for the crankcase breather and 90 deg. plastic connector for the isv. (I've done this before using silicone sealer and it worked fine)[ Edited Thu Mar 03 2005, 12:24PM ] Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 he wont need elbows as he already has carbon fibre ones same as me... just straight connectors but yeah with the isv connector (mines a 96 so doesnt have that) Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 like this(not quite that dirty anymore ) Link to post Share on other sites
Geastb 0 Posted March 3, 2005 Author Report Share Posted March 3, 2005 Thanks Justin/mightyVR6 - i'll have a look when i get home tonight.[ Edited Thu Mar 03 2005, 12:37PM ] Link to post Share on other sites
mightyvr6 0 Posted March 3, 2005 Report Share Posted March 3, 2005 binliner - where does your cc breather pipe go to? I can see it doesn't go into the intake. Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 do u mean cc as in carbon canister or cam cover?! lolwhen that pic was taken the carbon canister one went into the manifold as normal and the cam cover breather just had a filter on the end...since then Ive ditched the carbon canister and all the gubbins and just have a straight hose going from the cam cover to a dark corner of the engine bay with a filter on the end until I can find a suitable catch tank[ Edited Thu Mar 03 2005, 02:03PM ] Link to post Share on other sites
mightyvr6 0 Posted March 3, 2005 Report Share Posted March 3, 2005 Crankcase actually but you've answered the question anyway . I've got the same arrangement. The other way is to plumb the pipe into the intake (pre-charger) where yours is blanked off and fit a catch can inbetween.[ Edited Thu Mar 03 2005, 03:43PM ] Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 thats a good idea... but as mine is LHD Ive got a nice space to put a catch tank on the bulkhead where your brake servo is then again that'll mean using more hosing and silicone hose aint cheap Link to post Share on other sites
mightyvr6 0 Posted March 3, 2005 Report Share Posted March 3, 2005 I've got some odd lengths of samco if you need some in blue and black which I was using on my Z-kit. Might have enough to go from the breather to a catchcan if your interested? If so tell me the minimum measurement you need. Link to post Share on other sites
binliner 0 Posted March 3, 2005 Report Share Posted March 3, 2005 cool... I'll pm you Link to post Share on other sites
