paceo 22 Posted July 28, 2011 Report Share Posted July 28, 2011 whats a good PSI reading on each cylinder on the vr6 2.8?also if i remember from past cars, do you take the fuse out for the fuel pump and screw the PSI guage into the spark plug bore? Link to post Share on other sites
russj249 2 Posted July 28, 2011 Report Share Posted July 28, 2011 My compressions were roughly 150 - 180psi across all 6 cylinders.And to do the compression test remove spark plugs, the fuel pump fuse and make sure you disconect the coil pack too.. i got zapped trying to test a spark plug lead once on my VR6 - 1st time I've ever had a bad one and lost all feeling in my fingers for half hour or so!Also crank the engine over the same amount of times per cylinder. I normally count 5 - 6 times, or 5 or 6 seconds will probably be enough for an accurate reading. Link to post Share on other sites
paceo 22 Posted July 29, 2011 Author Report Share Posted July 29, 2011 cool what fuse is it, ive lost my black fuse cover :-( Link to post Share on other sites
Gazbarber1982 3 Posted July 29, 2011 Report Share Posted July 29, 2011 Fuse 18 Link to post Share on other sites
*P3nfold* 0 Posted August 1, 2011 Report Share Posted August 1, 2011 I checked a Peter Russek Manual on VR6's and its says the belowCompression pressure (new) - 11 - 13 kg/sq.cmMin. permissible pressure (wear limit) - 7.5 kg/sq.cm Link to post Share on other sites
cabrioman 6 Posted August 1, 2011 Report Share Posted August 1, 2011 or just unplug the main engine harness ..... Link to post Share on other sites
Goguvarra 0 Posted August 3, 2011 Report Share Posted August 3, 2011 i checked mine today and they all reported around 11-12 and one was about 9 . Should I worry about that one ? Does it affect driving ? Link to post Share on other sites
russj249 2 Posted August 3, 2011 Report Share Posted August 3, 2011 I don't think thats a massive drop to be honest. I can't remember properly but I think that's still within the tolerances. No doubt someone on here can inform you of what the tolerances actually are. Link to post Share on other sites
Goguvarra 0 Posted August 4, 2011 Report Share Posted August 4, 2011 well poster above said 7.5 is the lowest acceptable limit. I was just wondering if having a difference...well makes a noticeable difference in how the engine behaves ) Link to post Share on other sites
