rsweeney 40 Posted June 14, 2011 Author Report Share Posted June 14, 2011 same thickness and depth however old one has a lip making it fit better , i think this is why its leaking ? just tried it with old seal that has lip and still leaked but could be where it has chips out of it. Link to post Share on other sites
Vw_owner 1 Posted June 15, 2011 Report Share Posted June 15, 2011 thats a prety gnarly leak dude,idd order a new seal im prety sure that lip is only there because its been created over time by it being installed,i could be wrong though? i dont remember the front seal haveing a lip, part number for that seal is 038 117 070 Link to post Share on other sites
rsweeney 40 Posted June 15, 2011 Author Report Share Posted June 15, 2011 just ordered a new one incase the new one i bought thats leaking was wrong. im outta ideas on this one. does the cooler have to line up with anything on the engine ? like a return hole ??because maybe if oil is being pumped in but not escaping the pressure is causing it ? Link to post Share on other sites
Vw_owner 1 Posted June 15, 2011 Report Share Posted June 15, 2011 good point about the pressure build up, not 100% on this but if you look at my picture on page 1 you can see the block where it bolts to and a large circular hole {not the center hole} and on page 2 my picture that shows the bolt has holes in it, i think the oil flows through the large circular hole then through them holes in the bolt { center hole}back into the sump/engine? so not much to get blocked realy, i could be wrong though. Link to post Share on other sites
rsweeney 40 Posted June 15, 2011 Author Report Share Posted June 15, 2011 yeah i know what you mean, thats all clear so must be seal. it should come in friday then ill compare the two seals and give it another go. up to attempt number 7 Link to post Share on other sites
VR6Pete 1,455 Posted June 15, 2011 Report Share Posted June 15, 2011 Make sure you get genuine VW seals! Link to post Share on other sites
rsweeney 40 Posted June 17, 2011 Author Report Share Posted June 17, 2011 is it possible the oil cooler is on the wrong way ? and do both hoses off the oil cooler carry coolant ? Link to post Share on other sites
rsweeney 40 Posted June 17, 2011 Author Report Share Posted June 17, 2011 fixed it !! cooler was sitting the wrong way around so the front seal was only sealing on certrain parts. thanks so much for input just have to sieve coolant lost that i have caught and replace a few litres of oil and hope the two havent mixed ! Link to post Share on other sites
Vw_owner 1 Posted June 18, 2011 Report Share Posted June 18, 2011 ah glad you got it sorted,wrong way around? damn didnt think of that! Link to post Share on other sites
VR6Pete 1,455 Posted June 18, 2011 Report Share Posted June 18, 2011 I dont think you mentioned that you had removed the cooler the original thread suggested it just starting happening hehe, glad you all sorted though pal! Link to post Share on other sites
rsweeney 40 Posted June 20, 2011 Author Report Share Posted June 20, 2011 I dont think you mentioned that you had removed the cooler the original thread suggested it just starting happening hehe' date=' glad you all sorted though pal![/quote']sorry my fault completely, this was when putting the car back together after all its work being done so cooler wwas being refitted. and cheers just have to sort gearbox out now as reverse is knackered. Link to post Share on other sites
