DrRich 1 Posted April 15, 2011 Report Share Posted April 15, 2011 Hi there,I'm about to fit my 'new' VGI (thanks Tony!) and have a question about the wiring. I've wired up an OBD1 twice before without any problems, but the OBD2 ECU harness doesn't have the thick red/blue wire used on the OBD1. Almost all the guides on the 'net are about OBD1 and suggest that wire, so not relevant to me. The only OBD2 guide I can find is VENOM, which suggests a connector for a wiper relay - which mine doesn't have (it's a Mk2 VR6 conversion).Anyone remember or know where their power wire is tapped into for the control box? I've got the other two sorted but this is bugging me...Cheers for any help! Link to post Share on other sites
cabrioman 6 Posted April 15, 2011 Report Share Posted April 15, 2011 does this help ???Control box red wireThis is for 12V+ power. It taps into the thick wire in the ECU loom that that goes to ECU Pin 23. This wire is red/blue on OBD1 cars and Black/yellow on OBD2 cars.Control box black wireThis is the ground wire. It taps into the thick brown wire in the ECU loom that goes to ECU pin 1 (all models)Control box blue wireThis is the wire for the RPM signal. It taps into the green/black wire which goes to ECU pin 22 (all models). This connection to the ECU’s RPM signal wire allows the switch box to read your engine speed and activate the manifold flap at the correct RPM. The default switch point is 4000 rpm, suitable for all naturally-aspirated VR6s. For VR6s running superchargers, this is often changed to a lower value, but this should only be done by experienced tuning personnel during a rolling road re-mapping session. Link to post Share on other sites
DrRich 1 Posted April 15, 2011 Author Report Share Posted April 15, 2011 Brilliant Tony, just what I needed!BTW thanks for a very smooth purchase the other day - a nice bloke to deal with!Rich Link to post Share on other sites
cabrioman 6 Posted April 15, 2011 Report Share Posted April 15, 2011 no worries mate did u get my pm about the wheels ???? Link to post Share on other sites
DrRich 1 Posted April 15, 2011 Author Report Share Posted April 15, 2011 Actually I hadn't but just read it now. As it happens, just been offered some OZ Ultra's at a stupid price by a guy at work so probably go that way. Thanks for the thought though! Looking forward to seeing (and hearing!!) you at Inters... Link to post Share on other sites
paceo 22 Posted September 24, 2013 Report Share Posted September 24, 2013 cabrioman, on 15 Apr 2011 - 10:53 PM, said:does this help ???Control box red wireThis is for 12V+ power. It taps into the thick wire in the ECU loom that that goes to ECU Pin 23. This wire is red/blue on OBD1 cars and Black/yellow on OBD2 cars.Control box black wireThis is the ground wire. It taps into the thick brown wire in the ECU loom that goes to ECU pin 1 (all models)Control box blue wireThis is the wire for the RPM signal. It taps into the green/black wire which goes to ECU pin 22 (all models). This connection to the ECU’s RPM signal wire allows the switch box to read your engine speed and activate the manifold flap at the correct RPM. The default switch point is 4000 rpm, suitable for all naturally-aspirated VR6s. For VR6s running superchargers, this is often changed to a lower value, but this should only be done by experienced tuning personnel during a rolling road re-mapping session. is this the same for a very early obd1 vr6? located under the scuttle panel i guess?? Link to post Share on other sites
VR6Pete 1,455 Posted September 24, 2013 Report Share Posted September 24, 2013 should be, yes, although there's a full installation guide in the club members how-to section Link to post Share on other sites
paceo 22 Posted September 25, 2013 Report Share Posted September 25, 2013 should be, yes, although there's a full installation guide in the club members how-to section my friend is a paid member but there are no pictures of where the wiring goes! Link to post Share on other sites
paceo 22 Posted October 1, 2013 Report Share Posted October 1, 2013 any pics of where the wiring goes? Link to post Share on other sites
VR6Pete 1,455 Posted October 1, 2013 Report Share Posted October 1, 2013 There's nothing really to show to be honest mate... just locate your ECU and find the following, you can just tap into the following wires.... job done.... Control box red wireThis is for 12V+ power. It taps into the thick wire in the ECU loom that that goes to ECU Pin 23. This wire is red/blue on OBD1 cars and Black/yellow on OBD2 cars.Control box black wireThis is the ground wire. It taps into the thick brown wire in the ECU loom that goes to ECU pin 1 (all models)Control box blue wireThis is the wire for the RPM signal. It taps into the green/black wire which goes to ECU pin 22 (all models). This connection to the ECU's RPM signal wire allows the switch box to read your engine speed and activate the manifold flap at the correct RPM. The default switch point is 4000 rpm, suitable for all naturally-aspirated VR6s. For VR6s running superchargers, this is often changed to a lower value, but this should only be done by experienced tuning personnel during a rolling road re-mapping session. Link to post Share on other sites
paceo 22 Posted February 25, 2014 Report Share Posted February 25, 2014 ill include this for the buyer of mine! Link to post Share on other sites
