vr6jay 0 Posted February 11, 2005 Report Share Posted February 11, 2005 i have been having a few probs with my 93 vr6 my clifford got loads of water in it as a result of my matrix going! and its been playing up, now for sum reason which i dont think has nething to do with the alarm or imobiliser, the bloody thing wont start! it will turn over and try to fire but will not start!can any one suggest any ideas on what i can check? oh and the oil light is flashing when the ignition is on not sure if this means anything? it is full of oil tho i have checked.please help some oneregards Jay Link to post Share on other sites
acf8181 0 Posted February 11, 2005 Report Share Posted February 11, 2005 oil light will flash if your cranking it loads, thats normal.erm...first thing you need to work out is if its getting fuel. how much is in the tank? can you hear the fuel pump priming as you turn the ignition on (its in the boot)? can you hear the relays click as you turn the ignition on? Link to post Share on other sites
ingham 5 Posted February 11, 2005 Report Share Posted February 11, 2005 try dis connecting battery for 15-20 mins to reset ecu but as it is early may not work but its freeif it starts and runs but wont start after is ecu immobiser,may need recoding(vw only job)not sure about the flashing oil light thou Link to post Share on other sites
vr6jay 0 Posted February 11, 2005 Author Report Share Posted February 11, 2005 cheers for that i will look, if ne one else has ne ideas that would b great jay Link to post Share on other sites
acf8181 0 Posted February 11, 2005 Report Share Posted February 11, 2005 '93 don't have factory immob ingham...thats an obd2 only thing.you tried my suggestions to work out the prob jay? by the way, thats only the first few things to try...theres lots more! Link to post Share on other sites
shail 0 Posted February 12, 2005 Report Share Posted February 12, 2005 Check that your starter motor still has a good earth (braided strap can be seen from above). Mine was there but making poor connection = tried to fire, but couldn't. Link to post Share on other sites
acf8181 0 Posted February 12, 2005 Report Share Posted February 12, 2005 Check that your starter motor still has a good earth (braided strap can be seen from above). Mine was there but making poor connection = tried to fire' date=' but couldn't.[/quote']well, it wouldn't turn over if the starter wasn't working. Link to post Share on other sites
VRmonster 1 Posted February 12, 2005 Report Share Posted February 12, 2005 yeah, id go for fuell too, thats a really bad culprit, try pulling the fuel hoses out from the clips in the engine bay and turn the ignition on, they should jump due to the pressure of the pump priming the system. id also pull a spark plug to check that you have a spark, just wit till its dark, or find a shadow and hold it close to the intake manifold and have someone crank it over. should see a series of little sparks to the manifold.if theres no fuel id say, pump relay. if theres no spark id say igniton transformer/coil. ive this problem a few times and these were the culprits. been through 2 coils/transformers, crappy things. Link to post Share on other sites
vr6jay 0 Posted February 12, 2005 Author Report Share Posted February 12, 2005 bloody hell rite i have a major task on today then lol thanks for all the replies, hopefully i will get it sorted and maybe in the future i can help u guys out.cheers a lot jay Link to post Share on other sites
