finished my rotrex build today and have 2 problems.
vr6 obd1 aaa
1, the maf is popping quite loud on idle and trying to accelerate.
2, i thought the idle problem was sommat to do with the fuelling so disconnected the fuel regulator and fse and connected it all back up to where is was originally,when i disconnected the fuel feed pipe to the rail the fuel was under alot of pressure and squirted all over..i ran the fuel through a walbro 4 bar pump to the rail and the return pipe was connected to the fse and the return hose on the rail was blanked with a non return valve ifs thats any help.. thankyou for your help ill be on all night ;)
have you got the maf orintated the right way.. have you extended the wiring to it .. tbh bolting on the rotrex into a standard vr6 is a fairly simpe afair .
there are various ways of accomadting the extra power. a remaped ecu is the best way , but a rrfrp will work and still achive decent results.
what pulley do you have ? what spark plugs, what gap etc etc.
went to scrappies today picked up obd2 inlet manifold,throttle body and MAF and some wiring but do i need the EGR thingy. ive looked at the wiring and does anybody know how to wire the old 5 pin maf into the 4 pin only 1 wire shows voltage when ignition is on...I was thinking it may be due to the plugs as the old ones are new and the ones i have in now are from when i brought the charger mmm this may be the problem any thought on any thing else dudes
