michael5556 247 Posted January 23, 2011 Report Share Posted January 23, 2011 I am considering making one myself using the lower half of the manifold and welding a tube on so I can still use the standard fuel rail etc? How difficult would this be to make? Anyone done it before? Link to post Share on other sites
Antihero1981 8 Posted January 23, 2011 Report Share Posted January 23, 2011 if you search on google there are a few people who done them , also there was a guy selling a few on ebay a while back......think its possible , alot cheaper than buying a shimmel one..... Link to post Share on other sites
michael5556 247 Posted January 23, 2011 Author Report Share Posted January 23, 2011 Cool will check it out after work tonight Link to post Share on other sites
legvw 0 Posted January 23, 2011 Report Share Posted January 23, 2011 Not too hard to make, as long as you can tig weld.This is the 1 i made for my car. Link to post Share on other sites
michael5556 247 Posted January 23, 2011 Author Report Share Posted January 23, 2011 Is that using the lower manifold? And yeah can weld and have equipment to. Link to post Share on other sites
bungy 2 Posted January 23, 2011 Report Share Posted January 23, 2011 Here is one i've found on the net. I Think the way Paul tackled it would give more volume as it does act as a plenum. Link to post Share on other sites
legvw 0 Posted January 23, 2011 Report Share Posted January 23, 2011 Is that using the lower manifold? And yeah can weld and have equipment to.Yes, used the lower manifold, and welded to it. Link to post Share on other sites
michael5556 247 Posted January 23, 2011 Author Report Share Posted January 23, 2011 May try the first version next weekend depending on what materials I can get Link to post Share on other sites
FishWick 21 Posted January 24, 2011 Report Share Posted January 24, 2011 I've often thought about using the lower half of a schrick as the base for a shorty intake for it's balanced runner lengths. Although the ally quality is sheet compared to VW's, so it may not tig up that well.As always, if you're subjecting OE parts to welding, make sure it you get it skimmed afterwards to ensure the mating surfaces are flat. Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 It would only be the side where it attaches to the upper manifold I would be welding on. Would it still need skimming if i don't touch the mating side of manifold? Link to post Share on other sites
FishWick 21 Posted January 24, 2011 Report Share Posted January 24, 2011 Yip, it's a good idea to get it checked.A fellow VRT chap I know made his own shortcake with the stock lower half and he had no end of running issues with it. Turned out in the end to be a warped mating face because of the welding, so the intake gasket didn't seal properly on 2 cylinders. He got it skimmed flat again and it's been spot on since. Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Ah ok! Will skim it when it's made will post up some pictures once it's made should I aim the throttle body down so for the intercoolers? Or just put on a 90 degree bend hose? Link to post Share on other sites
dman78 1 Posted January 24, 2011 Report Share Posted January 24, 2011 is there a thread for your turbo build? Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Not yet as it's still a trial and error and doing it in a budget, under £1000 but it's getting there, should be done by Easter Link to post Share on other sites
dman78 1 Posted January 24, 2011 Report Share Posted January 24, 2011 doesnt matter mate,can only be trials no errors haha,still aint finished mine yet and i've got everthing in front of me to get it done,toooooooo coooooooold Link to post Share on other sites
FishWick 21 Posted January 24, 2011 Report Share Posted January 24, 2011 Ah ok! Will skim it when it's made will post up some pictures once it's made should I aim the throttle body down so for the intercoolers? Or just put on a 90 degree bend hose?It's up to you mate, angle the throttle where ever is convenient for you :-) Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Ah ok! Will skim it when it's made will post up some pictures once it's made should I aim the throttle body down so for the intercoolers? Or just put on a 90 degree bend hose?It's up to you mate' date=' angle the throttle where ever is convenient for you :-)[/quote']Won't a 90 degree bend restrict air flow though? Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 doesnt matter mate' date='can only be trials no errors haha,still aint finished mine yet and i've got everthing in front of me to get it done,toooooooo coooooooold[/quote']Well it currently consits of:A walbro GS5340 intank Bosch 044T15 turbo550cc high flow injectorsTial 38 waste gateCustom down pipe4" maf housingApexi avcr electronic boost controllerDecompression plateLightened flywheelArp rod and head boltsNgk race plugs312mm brakes(yet to be fitted)Intercoolers of seat Ibiza tdi Link to post Share on other sites
dman78 1 Posted January 24, 2011 Report Share Posted January 24, 2011 [blockquote]Well it currently consits of:A walbro GS5340 intank Bosch 044T15 turbo550cc high flow injectorsTial 38 waste gateCustom down pipe4" maf housingApexi avcr electronic boost controllerDecompression plateLightened flywheelArp rod and head boltsNgk race plugs312mm brakes(yet to be fitted)Intercoolers of seat Ibiza tdi [/blockquote]what power you aiming for? Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Around the 300 mark and it will be good Link to post Share on other sites
tjsmudger 2 Posted January 24, 2011 Report Share Posted January 24, 2011 Michael, you going to krispeys on Sunday? Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Unfortunately I work Sundays if only it was a Saturday! Link to post Share on other sites
tjsmudger 2 Posted January 24, 2011 Report Share Posted January 24, 2011 Blimey! How long till the vr is turbo'd? You seem to be cracking on at a right pace! Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Well it's my birthday on the 8th of may so aiming to have it all done and mapped by then then off to some shows, shame the paintwork is a bit off.I have another engine which I am rebuilding and am going to make it 'bomb proof with some wossner Link to post Share on other sites
michael5556 247 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Well it's my birthday on the 8th of may so aiming to have it all done and mapped by then then off to some shows, shame the paintwork is a bit off.I have another engine which I am rebuilding and am going to make it 'bomb proof' with some wossner pistons etc and rebuild the head with larger valves etc from shimmel but that won be done till summer then considering a updated r32 box with a diesel final drive. Then might concentrate on how it looks, but doubt it it's an addictive bug once you start making it faster Link to post Share on other sites
