Racelands 6 Branch Manifold
racelands go straight on, make sure your engine mounts are good, as theres no flexi joint on the bottom like the standard manifold. and its very important to heat wrap it.... its easier to do off the car, and you can do a better job....
Make sure you dampen the wrap in water as its contructed of fine fibres that are not nice to breathe in...
soak the nuts on your current exhaust manifold in plenty of WD40 for a while as they can be quite tricky to remove. careful you dont snap any studs!
one other note, is that the standard heat sheild doesnt line up properly, so be prepaired to 'manipulate' it slighlty to make it fit on the raceland...
