Plastic welding and bumper smoothing
Has anyone got any experience of plastic welding and bumper smoothing? I've watched a few films on youtube and looked at the equipment needed but would appreciate any advice and recommendations for the correct type of rods to use and flexible fillers for finishing.
u need to get the rods that match the type of plastic in the bumper, for it to weld properly.
also for ya flexible filler just go to your local paint suppler and ask for it.....cheaper then halfrauds lmao
and u will need a plasticiser additive u mix with your paint...this will allow the paint to flex without cracking. hope this helps
when I done my mk1 bumper what I did was cut out a rectangular section of the donor bumper and cut that into 2mm wide strips and used that as a 'welding rod' along with a normal soldering iron.Used a similar technique to oxy-acet for actual work although the process itself is more like brazing with the speed involved.
