Guest Olly_K Posted March 1, 2004 Report Share Posted March 1, 2004 what do you guys reckon........thinking about boring 2.8 to 2.9 or even 3.0...................has anyone done this............or does anyone know who can do this ?do really wanna source a raddo 2.9 cos its too much hassle ! Link to post Share on other sites
nickbee 1 Posted March 1, 2004 Report Share Posted March 1, 2004 In terms of bhp per £, boring out your engine is terrible. Either source a 2.9 or do something different (get a six-speed gearbox, lower ratios = more aceleration = more ). Link to post Share on other sites
dubloke 4 Posted March 1, 2004 Report Share Posted March 1, 2004 i have a 3.1 in the workshop ready to go back in once i've determined the damage from dropped valve! i bought 2.9 engine/gearbox/ecu etc complete and had that bored and stroked by tsr. the biggest you can bore the 2.8 safely to is 3.0, as the piston walls become too thin, so i was informed! although the price of a rebuilt 2.9 exchange at tsr is @ £3000 the last time i looked! Link to post Share on other sites
acf8181 0 Posted March 1, 2004 Report Share Posted March 1, 2004 agree with nickbee...do the box (get sealth to rebuild it as a six speeder with custom ratios and final drive, and a torque biasing diff).apparantly is like adding a serious dose of bhp to the car...but for less money. (you're talkin £1500 max, fitted) Link to post Share on other sites
Guest Olly_K Posted March 1, 2004 Report Share Posted March 1, 2004 thanks guys, i've heard that boring is tricky, might have a look at the gearbox a bit later (just managed to persuade the wife into the VSR!) Link to post Share on other sites
VR6Steve 0 Posted March 1, 2004 Report Share Posted March 1, 2004 Think you can bolt a 2.9 bottom end on new for £800 ish. Gearbox option sounds very interesting. Link to post Share on other sites
Guest Olly_K Posted March 1, 2004 Report Share Posted March 1, 2004 ok, this is gonna sound really thick but what is the bottom end ?the lower part of the block from the head (not including it) down ? Link to post Share on other sites
VR6Steve 0 Posted March 1, 2004 Report Share Posted March 1, 2004 Yep the main bit below the head, excluding the gearbox. Link to post Share on other sites
jcorallo 0 Posted March 1, 2004 Report Share Posted March 1, 2004 For info - the £800 sees you with a brand new block with new pistons direct from VW. It doesnt include crank, conrods, bolts, bearings, oil pump etc etc etc etc etc its just a block and 6 pistons.Jules Link to post Share on other sites
Guest Olly_K Posted March 1, 2004 Report Share Posted March 1, 2004 so in theory could i just buy that and use my old crank, etc ? Link to post Share on other sites
dubloke 4 Posted March 1, 2004 Report Share Posted March 1, 2004 eerrr no, not really! that'd be like replacing 4 spark plugs and leaving two old ones in! Link to post Share on other sites
Guest Olly_K Posted March 2, 2004 Report Share Posted March 2, 2004 oh ok ! Link to post Share on other sites
antera309 3 Posted March 2, 2004 Report Share Posted March 2, 2004 You would need to get your crank reground before fitting it into the new block. This doesn't actually cost that much if you remove the crank yourself and send it into the regrinders on its own. It gets sent back with a new set of shims, ready to go on. Link to post Share on other sites
antera309 3 Posted March 2, 2004 Report Share Posted March 2, 2004 Does the Corrado engine not have a longer-throw crank, though? Not too sure. Link to post Share on other sites
Hiten 0 Posted March 7, 2004 Report Share Posted March 7, 2004 If you need any work done i'd speak to Grant Motorsport. When it comes to VR6's he the man as he builds most of the engines in the VW Cup. Link to post Share on other sites
Guest Olly_K Posted March 7, 2004 Report Share Posted March 7, 2004 cheers hiten, do you have a link to grant ? Link to post Share on other sites
mina 0 Posted March 7, 2004 Report Share Posted March 7, 2004 http://www.grantmotorsport.com/ Link to post Share on other sites
Hiten 0 Posted March 7, 2004 Report Share Posted March 7, 2004 You can ring Grant on 07967 914362. Tell him that i gave you his number. Link to post Share on other sites
Guest Olly_K Posted March 7, 2004 Report Share Posted March 7, 2004 fank oooo guys ! Link to post Share on other sites
