What is the most BHP a N/A OBDI engine can produce without Forced Induction...
As title says anyone know what the safest useable BHP that can be had for the N/A route ...
It got me thinking as i was looking at page 82 of latest Redline the R32 there is N/A ... and wondered Ok VR6 OBDI is older has half the Valves but surely something like 300BHP is possible and usable for a Daily ???
But here's the handcuff's i don't want to do a Schrick inlet...... ha ha ha
Skim head
Flow it
Cams
De Cat
Exhaust
Filter
Power Pulleys
ECU remap = 270 BHP ???
and good dose of Nitrous at 50hp jets = 300 BHP ....
Would that little lot require bigger injectors & uprated fuel pump ????
Might look in to these then but if they are £££ then i will go to the prescribed way cams, de cat etc and re map if i can get 200 or 220 then i'm happy as i can make up the short fall with NOS to around 275 - 300BHP ... Cheers TONY
Are you going to do all the mods at the same time? If so how much money are you spending?
Mine has had a stage 1 AmD remap and stuff and runs 196bhp on the rollers. Apart from the extra breaks, it's a super smooth delivery of power and it's my daily driver. I still get a good mpg of 32/33 on normal driving.
if your looking for itb's, it's cheap, well here by us
the total setup of itb's on my mk1 cost me £500, and it was well worth the cash, a vr6 on ITB's is the bees!!!!
im doing the same as you, but saving and i know exactly what i want to do.
3.1 bore $400
headwork $300
cams 272/276 $290
Wolf / gotech management $490
gruvenwerks power pulleys $350
BMC CDA - $200
headers - $350
Full wet shot nos kit - $400
so far i got the gruvenwerks power pulley kit, and cams laying in my room, waiting to get a spare head to flow and save and build from there.
im going to put this in Rand ( ZAR) and then we convert ( i live in cape town, south africa)
43mm toyota ITB's silvertop -R1000
Fuel rail -R250
290cc injectors R600
intake Rowland Stanton- R1500
Dicktator fuel mangement R2000
fitting (JVS TUNING)- R1200
R6550 ( 596.038 GBP)
these are for the parts new and fitting
i got them second hand and had it fitted for R4500 (409.587 GBP)
my mk1 makes (not sure on bhp) 127kw and 225nM without headwork :-#
i love living in a third world country filled with mk1,mk2 parts, vr parts are hard to come by here by us but mk1 and 2, easy peasy!!!
I cant afford to go down the shrick route as yet. I was speaking to Vince and he suggested Shimmel 268 or 263 Cams which according to Vince are near enough to what you can get to VGI performance. So cams coupled with exhaust filter and chip should be able to give you atleast 20 bhp if your VR is healthy. 260 BHP is rather optimistic with an NA engine.
So really compared to most cars out there there isn't that much N/A performance to be had out of VR6's ... However having done much research on the Subject basic improvements like 6 branch , de cat pipe, and exhaust filters and re map does bring it to over 200bhp... I can see only one way to reach the 300bhp mark NOS and looks like a 100bhp shot is easily done on stock internals...SO i believe that's the rute to go...
