gavinvr6 0 Posted September 19, 2010 Report Share Posted September 19, 2010 right, just a simple query, is it possible to fit the mk3 clutch pedal into a mk2? essentially that's the only part of a conversion that means you gotta swapthe whole pedal set.understand the mk3 clutch bracket will need a little tinkering but will it join up to the mk2 main pedal assembly?the clutch pedals and bracket on a mk2 is seperate from the main pedal assembly but im having probs removing the mk3 pedals in order to compare them.yes i know a rado one can be used and also a passat b5 but i cant find one of these at a sensible price. if it's not possible then i'll just run a cable clutchh and keep a couple of cable's spare in the boot for emergenciesif anyone has a rado hydrolic pedal set or the correct passat one then get in touch and we'll talk cash Link to post Share on other sites
GVK 1 Posted September 20, 2010 Report Share Posted September 20, 2010 Last time I wanted a Corrado pedal box I put wanted ad up on Corrado forum, paid £70 for it which was a bit steep. Link to post Share on other sites
mattyvw 0 Posted October 25, 2010 Report Share Posted October 25, 2010 they seem to be getting more and more expensive paid £100 for mine with cylinders and pipework Link to post Share on other sites
bluerush1985 0 Posted October 26, 2010 Report Share Posted October 26, 2010 apparently you can use a passat pedal box but you need same master cylinder Link to post Share on other sites
justarn 0 Posted January 16, 2011 Report Share Posted January 16, 2011 hey soory to hijack, i have a mk1 vr obd2, it has a cable clutch! it grinds what cable would it most likely be? also would i be better off with carrado pedals and hydrolic clutch? will it bolt straight up? Link to post Share on other sites
JamesSvr6 1 Posted September 7, 2012 Report Share Posted September 7, 2012 hey soory to hijack' date=' i have a mk1 vr obd2, it has a cable clutch! it grinds what cable would it most likely be? also would i be better off with carrado pedals and hydrolic clutch? will it bolt straight up?[/quote']The cable will be a Seat part.Hydro pedal box does not bolt right in. Probably why the person who did the conversion didn't bother. The clutch/hydro setup is a bit of a half assed way of doing it in my opinion and most people end up converting to hydro at a later date when the cable snaps or they get fed up with the heavier clutch feel. Best option is a Rado vr6 pedalbox. You need to hammer the firewall flat and drill a hole where the clutch master cylinder is located and you also need to cut and move the pedalbox top bracket over 20mm or so to make it fit properly. It will take you a good 6 hours+ to do it because there is dissassembly, marking out, hammering, drilling, trial fitting, measure twice, cut once!, cutting, welding, painting and assembly. Have fun! Poriordan 1 Link to post Share on other sites
Database14 0 Posted November 5, 2012 Report Share Posted November 5, 2012 why not swap for Passat B3/B4 cluster, direct bolt on, more common and cheaper too:) Link to post Share on other sites
