nickg123 0 Posted January 17, 2005 Report Share Posted January 17, 2005 Sat in traffic last night, i had my window down slightly, and around 1k revs, there's quite a noticable "rattle" sort of sound from the engine.I know it's Chain driven, my car's a 1997 P Reg, is it likely to be the Chain Tensioners or something? Mileage is 83k, it's not that loud but doesn't sound particularly nice that's all? Link to post Share on other sites
stu h 0 Posted January 17, 2005 Report Share Posted January 17, 2005 could it be the exhaust heat shield rattling / vibrating??used to do it on my mk2 at 3k revs. think is a common complaint on mk3's (?) Link to post Share on other sites
nickg123 0 Posted January 17, 2005 Author Report Share Posted January 17, 2005 It's a lot lower down the revs, around the 1k mark, just before - literally if you just press the pedal slightly it starts to do it..... i'll get that checked though - thanks mate.Just paranoid i'm going to need the Chain and Tensioners doing ;-) Link to post Share on other sites
VR6Pete 1,455 Posted January 17, 2005 Report Share Posted January 17, 2005 mine is on 83k and the chains need doing, going through a particular echoy area (like drive thru) it's even worse! just rev ur engine slighty and listen to the engine Link to post Share on other sites
acf8181 0 Posted January 17, 2005 Report Share Posted January 17, 2005 does sound like chains...whcih reminds me, i have some scary pics of what happened on a '96 highline at 108k. i'll upload them and post them. Link to post Share on other sites
Slim 0 Posted January 17, 2005 Report Share Posted January 17, 2005 I hate to scare you but it sounds like you've got one of these under your bonnet: Link to post Share on other sites
nickg123 0 Posted January 17, 2005 Author Report Share Posted January 17, 2005 lol @ Rattler pic!How can i tell if it's the chain then? It's definitely bad when parked up next to a wall, sounds rattly.... Link to post Share on other sites
Seademon 0 Posted January 17, 2005 Report Share Posted January 17, 2005 Oooh mine has the same top end rattle !dodge Mines a P reg with 66k miles on it - taking it to the Nurburgring in June so if it is the chain/tensioners Im gonna get them done before I do a 1500 miles trip where I'll be pretty much flat out most of the way! Link to post Share on other sites
VRVIRGIN 0 Posted January 17, 2005 Report Share Posted January 17, 2005 Theres a sound sample link on a thread somewhere. Gonna see if i can locate it for you. Link to post Share on other sites
Tommo 0 Posted January 18, 2005 Report Share Posted January 18, 2005 It' here.http://forums.vwvortex.com/zerothread?id=1127339Tom Link to post Share on other sites
nickg123 0 Posted January 18, 2005 Author Report Share Posted January 18, 2005 Hmm can't really tell from that.Next question - does anyone know roughly how much it costs to get this done at a decent Non VW Garage? Link to post Share on other sites
acf8181 0 Posted January 18, 2005 Report Share Posted January 18, 2005 £600they shouldn't really be going at 60k though (disclaimer - i ain't saying they're fine though).seademon - i was in the same situation last year, get it done now so you know its fine. Link to post Share on other sites
nickg123 0 Posted January 18, 2005 Author Report Share Posted January 18, 2005 £600 Ouch!!!Don't really see what choice i have to be fair, it sounds like it needs doing going by the descriptions on here........ gutted!Didn't expect to have to spend £600 on a VR6 within 2 months of ownership, i thought it'd go way past 100k without any major work being done! Link to post Share on other sites
simey 0 Posted January 18, 2005 Report Share Posted January 18, 2005 I had a rattle and thought it was the top end, it turned out piston 1 & 2 were hitting the head. Hopefully it will be just the chains.. Link to post Share on other sites
badboyV6 4 Posted January 18, 2005 Report Share Posted January 18, 2005 It could be tappets mind you, mine sound a bit shitty occasionally. 65k sounds a bit low low for a work chain- as ACF says though - disclaimer get it checked though as you never know!! Link to post Share on other sites
acf8181 0 Posted January 18, 2005 Report Share Posted January 18, 2005 you could whip the inlet manifold/cam cover/coilpack/add water pump/tensioner bolt/top chain cover off (in that order) and have a look at the condition of them yourself first. Link to post Share on other sites
Seademon 0 Posted January 18, 2005 Report Share Posted January 18, 2005 I'll get the guys that usually work on my car to check it out & I'll definately get it done if it is teh chain - much rather shell out for that than a new engine! It does seem to quieten down once the engine is hot so could be just the tappets - I'll get it checked! Link to post Share on other sites
