sefton 0 Posted January 17, 2005 Report Share Posted January 17, 2005 After speaking to a few mk3 owners would I be correct in saying...when you lower a mk3 with eibach/koni setup the front sits slightly higher than the rear?Craig. Link to post Share on other sites
nickbee 1 Posted January 17, 2005 Report Share Posted January 17, 2005 On a normal VR there's a bigger gap between the wheels and the arches at the front, but you don't notice it. When you lower the car the gap at the back disappears and the other is still a gap so it's more apparent, that's all. The car will still sit level. Link to post Share on other sites
acf8181 0 Posted January 17, 2005 Report Share Posted January 17, 2005 yeah, the front wheel arch is bigger anyway, as the wheels have to turn. same on all cars.if you had the same gap at both ends the car would look 'nose down'. Link to post Share on other sites
jonvr6highline 0 Posted January 17, 2005 Report Share Posted January 17, 2005 Mine does that with Eibach springs and Boge shocks!Much better than standard though! The Range Rover look! 8) Link to post Share on other sites
cliveyp 0 Posted January 17, 2005 Report Share Posted January 17, 2005 mines a nose down-er. Looks odd! Link to post Share on other sites
sefton 0 Posted January 17, 2005 Author Report Share Posted January 17, 2005 heard about these 10mm lowering caps to bring the front down level with the rear...any one run these?Craig. Link to post Share on other sites
badboyV6 4 Posted January 17, 2005 Report Share Posted January 17, 2005 Mines a nose downer too- looks like a baja bug from the back Link to post Share on other sites
tommy 0 Posted January 17, 2005 Report Share Posted January 17, 2005 mine's also a nose downer....it look much better IMO over the arse in the arch look Link to post Share on other sites
MrBen 0 Posted January 17, 2005 Report Share Posted January 17, 2005 heard about these 10mm lowering caps to bring the front down level with the rear...any one run these?Craig.Me! See my reply on your CGTI thread! Link to post Share on other sites
Macca 1 Posted January 17, 2005 Report Share Posted January 17, 2005 Another nose downer here! Think id prefer it a bit lower at the back to be honest. Link to post Share on other sites
sefton 0 Posted January 17, 2005 Author Report Share Posted January 17, 2005 so unless I get the lowering caps or coilovers (which I cant afford)...then it will be nose up??? Link to post Share on other sites
nickbee 1 Posted January 18, 2005 Report Share Posted January 18, 2005 No, it won't be 'nose up' it'll be level. You're either level or nose-down. Link to post Share on other sites
