RAPgolfvr6182 2 Posted May 24, 2010 Report Share Posted May 24, 2010 just wondering if these are the correct brake discs for my golf vr6 1996. 288mm discs. I think they are the correct ones.http://www.bremboshop.co.uk/brembo-max-volkswagen-golf-iv-18i-20v-turbo-gti-front-discs-09701076_p4151363.htm Link to post Share on other sites
Pearsy47 1 Posted May 24, 2010 Report Share Posted May 24, 2010 http://www.bremboshop.co.uk/brembo-max-volkswagen-golf-iii-28i-vr6-front-discs-09557075_p4151351.htmthat would be the correct ones ! Link to post Share on other sites
RAPgolfvr6182 2 Posted May 24, 2010 Author Report Share Posted May 24, 2010 http://www.bremboshop.co.uk/brembo-max-volkswagen-golf-iii-28i-vr6-front-discs-09557075_p4151351.htmthat would be the correct ones !cheers but there to small there only 280mm not 288mm Link to post Share on other sites
Pearsy47 1 Posted May 24, 2010 Report Share Posted May 24, 2010 oh i see yer fuck knows they should be 288mm ring up just to make sure that stie isnt just wrong lol Link to post Share on other sites
jesterwalker69 0 Posted May 24, 2010 Report Share Posted May 24, 2010 http://www.bremboshop.co.uk/brembo-original-volkswagen-golf-iii-28i-vr6--19951997-front--discs-09674710_p4140928.htmThese are the right size but not the "MAX" ones Link to post Share on other sites
RAPgolfvr6182 2 Posted May 24, 2010 Author Report Share Posted May 24, 2010 oh i see yer fuck knows they should be 288mm ring up just to make sure that stie isnt just wrong lol early vr6 came with 280mm as standard they changed size on a 1995 vr6 so sum 1995 vr6 have 280mm and others have 288mm those ones u pointed to are for pre 1995 models with 280mm discs Link to post Share on other sites
jesterwalker69 0 Posted May 24, 2010 Report Share Posted May 24, 2010 oh i see yer fuck knows they should be 288mm ring up just to make sure that stie isnt just wrong lol Not necessarily. Earlier VR's only had 280mm Link to post Share on other sites
RAPgolfvr6182 2 Posted May 24, 2010 Author Report Share Posted May 24, 2010 http://www.bremboshop.co.uk/brembo-original-volkswagen-golf-iii-28i-vr6--19951997-front--discs-09674710_p4140928.htmThese are the right size but not the "MAX" onessame size as the mk4 gti turbo ones i posted it the bore size im wondering there both 288mm with a thickness of 25mm but it doesnt list bore size for the standard disc Link to post Share on other sites
rodney 17 Posted May 24, 2010 Report Share Posted May 24, 2010 I think iirc that ones you found aren't vented... and yes you should have 288mm on there.But if your after an upgrade at the same time and have the wheel size - (16"+ ) then the 302mm TT set up is a big immprovement with out the need to upgrade servos/sensors/resevoirs etc etc etc etcThe standard Brembo discs and improved pads (fast road) should be fine unless you have something special planned.. Link to post Share on other sites
craggsy 91 Posted May 24, 2010 Report Share Posted May 24, 2010 http://www.bremboshop.co.uk/brembo-max-volkswagen-golf-iii-28i-vr6-front-discs-09557075_p4151351.htmIt has VR6 in the list of brembo max....so get what they say Link to post Share on other sites
CALICO 130 Posted May 24, 2010 Report Share Posted May 24, 2010 your link is for 280mm ones craigand RCF audi's are 312mm not 302mm Link to post Share on other sites
Rikki 2 Posted May 24, 2010 Report Share Posted May 24, 2010 FFS for how much your gonna spend on them you might aswell get 312 carriers and discs with the 6mm longer bolts and washers!!!!! will be better than them anyway! shall we just say that the website forgot to list the 288 for the mk3 Link to post Share on other sites
RAPgolfvr6182 2 Posted May 25, 2010 Author Report Share Posted May 25, 2010 FFS for how much your gonna spend on them you might aswell get 312 carriers and discs with the 6mm longer bolts and washers!!!!! will be better than them anyway! shall we just say that the website forgot to list the 288 for the mk3thats the problem they havent forgot to list it, according to brembo they dont make the brembo max ones for a golf vr6 288mm. but they do make the same size disc for other applications ie galaxy vr6 sharan vr6 passat vr6 etc. 312mm discs would cost even more as only have 15" standard bbs wheels so would need another set of alloys. Link to post Share on other sites
Jamesr_VR6 0 Posted May 25, 2010 Report Share Posted May 25, 2010 Plus i dont think he wants to upgrade as nothing special is plannedjust a replacement for worn dics?these are what your afterhttp://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.8_1996/p/Car-Parts/Brakes/Brake-Friction/Brake-Discs/?104440358&1&50dffd53b1d3846bf1a779b056d3527e6acd338e&BDIS Link to post Share on other sites
RAPgolfvr6182 2 Posted May 25, 2010 Author Report Share Posted May 25, 2010 Plus i dont think he wants to upgrade as nothing special is plannedjust a replacement for worn dics?these are what your afterhttp://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.8_1996/p/Car-Parts/Brakes/Brake-Friction/Brake-Discs/?104440358&1&50dffd53b1d3846bf1a779b056d3527e6acd338e&BDIScheers james ur spot on i havent got nething planned for the golf in fact not sure its going to be round much longer. but the discs are worn and need new ones just replaced the rears with brembo discs and ebc greenstuff pads. but need the front doing, it doesnt matter if it says golf gti 1.8 turbo on the listing will the disks fit a mk3 golf vr6 disk dia is same along with thickness is the stud pattern and bore for the centre the same on a mk4 and a mk3? Link to post Share on other sites
