VAG COM on vista install help
If you right click on the vagcom shortcut, it should bring up this menu. Not sure if it works on 64 bit windows though, that could be your problem. To find out if your system is 32 or 64 bit, click start, right click on computer and click properties. It should tell you in the next window.
Just in the car trying to get it to work, where you can test if its obd2 compatable i tried that and it says its not obd2 compatable, i can plug it in, select comm 3 and get
interface found,
port ok, type:
serial pass-Through,
opto/iso:NO
ross-tech design:NO
It just wont find any codes etc!
thats when i go into options to test the comm port, comm3 gives that as a pop up.
I now know why this will not work. My ecu is knackered! thats why my car isnt starting, absolutly gutted. Also tryed plugging in a friends diagnostics tool which wouldnt pick up the car, a snap on diagnostics which would not pick up the car and this vagcom i have got which would not pick up the car.
Just doing my bit to help. Kie' date=' you read the rest of bungy's thread? Turned out to be a blown fuse as vagcom would read all the other controllers
The lucky boy, lol, wish mine was a fuse, ive checked all of mine and they are all fine. Im going to scan my mates car soon with my vagcom make sure it was deffo down to my ecu, deffo is though lol
