Lukey. 381 Posted March 30, 2010 Report Share Posted March 30, 2010 Ive had braided hoses fitted and it feels like air in the lines even after pressure bleeding twice, i swapped to braided hoses to get better feel and its far worse!Its spongy like theres air still in there somewhere even though there apparently cant be, the pedal has to travel further to get any response tooAny help?Cheers Link to post Share on other sites
spadam 7 Posted March 30, 2010 Report Share Posted March 30, 2010 Think you made need to bleed abs as this is what id putting me off changing my pads and disks lol. Not to sure how you bleed abs but someone will soon tell you Link to post Share on other sites
Lukey. 381 Posted March 30, 2010 Author Report Share Posted March 30, 2010 thats my thought too, though the ex VW mechanic doing it for me didnt really listen to my suggestion even though it will only take a 10 second procedure Link to post Share on other sites
ingham 5 Posted March 30, 2010 Report Share Posted March 30, 2010 i think vag com can cycle abs for bleeding, i changed my fluid with engine running and had no problems Link to post Share on other sites
Lukey. 381 Posted March 30, 2010 Author Report Share Posted March 30, 2010 As the original lines had 13 years exposure to muck and weather the ends were all welded together, so I had to cut the metal lines and run new lines, so they were disconnected from the ABS pump, im getting surer and surer that it needs vagcom to purge the valves.Theyve suggested that each corner wants blocking off with a sealed plug then bleeding 1 corner at a time too now, but i thought thats what the bleed nipples are for no? Link to post Share on other sites
VR6Pete 1,455 Posted March 30, 2010 Report Share Posted March 30, 2010 yep - use VAG-com to cycle the ABS Link to post Share on other sites
vr6stormt 0 Posted March 30, 2010 Report Share Posted March 30, 2010 Ive had braided hoses fitted and it feels like air in the lines even after pressure bleeding twice' date=' i swapped to braided hoses to get better feel and its far worse!Its spongy like theres air still in there somewhere even though there apparently cant be, the pedal has to travel further to get any response tooAny help?Cheers[/quote']ive got this problem to about 2 months ago i changed front & rear discs pads and fitted a set of goody`s and my brakes feel the same like they have air in the system even after pressure bleeding, i have been using it, under normal driving it stops but if i rag it and have to stop quick well put it this way there`s been some hairy moments is this an easy fix with the vag-com????? Link to post Share on other sites
Lukey. 381 Posted March 30, 2010 Author Report Share Posted March 30, 2010 whats the exact procedure in vag com to do an ABS purge? Link to post Share on other sites
spadam 7 Posted March 30, 2010 Report Share Posted March 30, 2010 Do you need full vag com aswell. I take it my ebay lead would not work to do this. Link to post Share on other sites
Lukey. 381 Posted March 30, 2010 Author Report Share Posted March 30, 2010 i have a registered 409.1us that i think will work with an ebay lead, according to google the .us part means it will work with a usb leadso i hope universal leads do cos thats how ill be trying it Link to post Share on other sites
Lukey. 381 Posted March 30, 2010 Author Report Share Posted March 30, 2010 These snippets of information are what i have found so faroff vwvortex,IIRC there is a procedure to bleed the brakes using the vag-com.You put the car up on jacks,connect the vag-com.Select ABSthen one of the options on the ABS screen gives you the testing / bleeding procedure.You need 2 people, one to operate the vag and the brake pedal the other to bleed the brakes as required by the vag display.The software takes you through the whole process telling you when to apply brake pressure and what bleed screws to open and close.IIRC it's just the front bleed screws used.someone else on a gti-vr6 website or something,Then cycle the pump using the VAG-COM software. To do this, choose “ABS Brakes†from the main menu. Then select “Test Output†and follow the on-screen instructions. The computer will cycle the pump, and then test each of the valve positions, one corner at a time. After this is done, you should have good brake feel again. I’ve heard that running the pump for more than 30 seconds or so could lead to the pump overheating and susbsequent damage, so accomplish this procedure reasonably quickly.from Ross tech themselves,Procedure for Bleeding the ABS Brake Pump on VW Golf, GTI, Jetta, and Audi TT:[select][03 - ABS Brakes][basic Settings - 04]Group 001[Go!]This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.Click the [Done, Go Back] button and you're all set.Then backed up again by a rosstech employee off an audi website about bleeding a 1998 audi a3You've got a Teves 20, almost identical to the one I had in my 1997 Golf VR6. I don't think there's any harm in starting the Output Test sequence or the Bleeding Sequence (Basic Settings Group 001) and then aborting it after you've verified that the pump runs. I've done both in the distant past on the VR6 (which I sold in 2002) but neither of these is an "approved" procedure in the repair manual so I'm not going to give you any iron-clad guarantees.So i am assuming as its in so many places this is the correct method? Link to post Share on other sites
b road blaster 0 Posted March 30, 2010 Report Share Posted March 30, 2010 not hard to do with vag-com mate it will lead you through the procedure i have got a licened version 908 so if you get stuck give me a shout only in chichester so not to far from southampton (vrstormt) Link to post Share on other sites
craggsy 91 Posted March 30, 2010 Report Share Posted March 30, 2010 When I changed front calipers and put goodridge hoses on my brakes felt spongy but still worked......and Jody at Midland VW did em. They did come back to me after about 3 days driving Link to post Share on other sites
vr6stormt 0 Posted March 30, 2010 Report Share Posted March 30, 2010 not hard to do with vag-com mate it will lead you through the procedure i have got a licened version 908 so if you get stuck give me a shout only in chichester so not to far from southampton (vrstormt)thanks mate your a life saver i will defo be up for sorting it out it`s rubbish compared to what it was like it feel so spungy since i fitted the grooved an drilled discs greenstuff pads and goodridges all round thought this was an upgrade not down grade lol if you pm your number i will give you a call thanks again.... Link to post Share on other sites
b road blaster 0 Posted March 30, 2010 Report Share Posted March 30, 2010 pm sent mate Link to post Share on other sites
baz8328 0 Posted March 30, 2010 Report Share Posted March 30, 2010 Im gonna need some help with mine in the next couple of weeks . Anyone in the Lincs area ?? available to help ??? Link to post Share on other sites
Bigjobbo 0 Posted March 30, 2010 Report Share Posted March 30, 2010 Why don't you just bleed all nipples? I just connected a pressure bleed and opened all the nipples rear to front, no VAG-COM, no 5051. Simples. Link to post Share on other sites
Lukey. 381 Posted March 30, 2010 Author Report Share Posted March 30, 2010 did that, but i cut the lines so it removes the current integrity of the hydraulic system or sommat, i had the front lines disconnected as it was easier to run all new fronts. See what happens tomorrow hopefully the OBD2 usb will hook up as its not been up to the car yet so dont know if it'll make a successful connection till i try it. Link to post Share on other sites
vr6stormt 0 Posted April 2, 2010 Report Share Posted April 2, 2010 big thanks to b road blaster aka russ for braving the weather and purging my abs pump and now the sun is out (typical) lol when i get the three abs sensors i`ll drop you a line to come over cheers again mate... Link to post Share on other sites
b road blaster 0 Posted April 2, 2010 Report Share Posted April 2, 2010 not a prob mate yeah i got home to lovely sunshine as well lol lol hope they feel abit better if not we will have another go (on a sunny day) Link to post Share on other sites
vr6stormt 0 Posted April 2, 2010 Report Share Posted April 2, 2010 they do feel a bit better... Link to post Share on other sites
Lukey. 381 Posted April 2, 2010 Author Report Share Posted April 2, 2010 I bled my ABS pump and system with vagcom using the basic bleed and also turned the rears upside down to release any air pockets. I also used the output test to run each corner through the pump with the bleed screws open and air bubbled out. This improved things markedly but still felt a bit numb and there was about an inch or so of nothing before any resistance was felt even thought there was def not a lack of power. Having a goof B-road blast to give the brakes some good exercise has brought all the meat back and it now has resistance right from the top of the pedal.All in all, success Link to post Share on other sites
vr6stormt 0 Posted April 3, 2010 Report Share Posted April 3, 2010 when you say you turned the rears upside down you removed and then the bleed nip`s were at the bottom? and when we done the auto bleed to mine it was only the fronts the vag-com done, me thinks now i need to have another go probably best to do it when it`s not forecast rain (lol russ) was this on the full (newest vag-com version)? Link to post Share on other sites
b road blaster 0 Posted April 3, 2010 Report Share Posted April 3, 2010 yeah we can do them again and have also done a bit of research and we can undo the bleeds on the rear then run the output test and that should also pump the fluid throughbasicly the same as lukeyb has done so just let me know when you wanna do them mate Link to post Share on other sites
vr6stormt 0 Posted April 3, 2010 Report Share Posted April 3, 2010 ok mate thats good i will get the abs sensors fitted and then have ago... Link to post Share on other sites
