dman78 1 Posted March 18, 2010 Report Share Posted March 18, 2010 im getting some top mounts but there are bearing and non-bearing top mounts,which one is the better choice for a coilover set up? Link to post Share on other sites
Ian_rogers 0 Posted March 18, 2010 Report Share Posted March 18, 2010 I think the fronts have to be bearing ones, rear non bearing, someone will confirm Link to post Share on other sites
Knightrider 1 Posted March 18, 2010 Report Share Posted March 18, 2010 Fronts have bearings. You can just change the top mount and use the old bearing. But as I bought proper VW OEM bearings from my local VAG Trade Parts Specilaists (I'm not trade ) for £4.92 inc VAT each, you might as well put new ones in while you are at it.The VW top mounts were £13.00 each.I'm told it is not worth putting in cheaper after market non VW items - these can wear out very quickly, especially if you have coilies and given the current state of the roads.Venom do Polyurethane Top Mounts by Supersport - they drop the front by an extra 10mm I think. Probably better, harsher and won't wear out!! Think they are only about £50.00 per pair. Link to post Share on other sites
