Tighten up a sloppy gear change
I have just had my car super charged and it freaking flys!
No I need to tighten up the gear change as its just too sloppy. Its a little notchy going into a couple of the gears and the lever is just a bit loose.
Is there a bushing refresh kit available like on mk1s?
Or is there a nice upgraded shift kit worth getting?
Amit
Yer thats the baby!
Doesn't take all that long to install. You do need to get under the car though so access to lifts would be a great help.
You basically remove the exhaust section that runs under the shifter. Loosen all relevant screws and connections and drop the shifter assembly out. Then reverse the procedure with the new assembly. Shouldn't really take a garage more than an hour 30 - 2hrs very max. But worth it imo :)
