J5KE F 0 Posted November 20, 2009 Report Share Posted November 20, 2009 :^) Help!!!???I have a rattly noise coming from my box..?On further inspection the noise was eminating from the inspection cover on the side of the box soI have removed the n/s wheel and removed the 6x 11mm box cover bolts and a small amount (approx 200ml) of gear oil dripped out.I am hoping that the rattle was just not enough oil?Does any 1 know the required amount of oil and where to put it in??Thanks Link to post Share on other sites
Dave_ciw 507 Posted November 20, 2009 Report Share Posted November 20, 2009 Is far as I know jake you fill it up on level ground untill it starts to flow out of the whole and thats it. But you may be better off ringing VW on this one mate. Link to post Share on other sites
VR6Nat 9 Posted November 20, 2009 Report Share Posted November 20, 2009 Tony put 2 litres in mine and just as he put the last bit in it started to come out of the hole, so think thats the right amount. Link to post Share on other sites
VR6Nat 9 Posted November 20, 2009 Report Share Posted November 20, 2009 Here you go, just to confirm,,,, Link to post Share on other sites
VR6Pete 1,455 Posted November 20, 2009 Report Share Posted November 20, 2009 yep, fill upto the hole Link to post Share on other sites
J5KE F 0 Posted November 20, 2009 Author Report Share Posted November 20, 2009 Ok Thanks all you are all very helpfull and thanks nat for the volume chart! however can u confirm this is the hole..?Thanks.. Link to post Share on other sites
VR6Nat 9 Posted November 20, 2009 Report Share Posted November 20, 2009 No its not that, its on the front of the gearbox facing you, its not on the top, its on the side so makes getting the fluid in a bit akward, but its bigger than that too... Link to post Share on other sites
J5KE F 0 Posted November 20, 2009 Author Report Share Posted November 20, 2009 Oh I see it.. a rather large hex bolt.. ok refink needed my tool just isnt large enough! Link to post Share on other sites
VR6Nat 9 Posted November 20, 2009 Report Share Posted November 20, 2009 hahahahaha, yeah thats the one!! Link to post Share on other sites
J5KE F 0 Posted November 20, 2009 Author Report Share Posted November 20, 2009 Thanks Nat.. Ur a gem Link to post Share on other sites
VR6Nat 9 Posted November 20, 2009 Report Share Posted November 20, 2009 No problemo... Link to post Share on other sites
