faigolfgti 0 Posted October 27, 2009 Report Share Posted October 27, 2009 As topic above,I am plan to get this AUTOTHORITY chip for my vr6 and claim by the company webpage this is the best chip for vr6,most of the other performance chip only tune for full thorttle performanceonly .All comment are welcome.Thank You. Link to post Share on other sites
sharky_70 0 Posted October 27, 2009 Report Share Posted October 27, 2009 not sure it will work properly on the european ECU Link to post Share on other sites
VR6Pete 1,455 Posted October 27, 2009 Report Share Posted October 27, 2009 To be honest - you wont get that much of a performance improvment from simply chipping the ECU. Link to post Share on other sites
faigolfgti 0 Posted November 2, 2009 Author Report Share Posted November 2, 2009 Thanks for reply,the upgrade i already done to my vw golf mk3 vr6 is schrick vsr inlet manifold,cat 256 performance camshafts,abt exhaust system CAT remove,corrado vr6 2.9 thorttlebody,k&n panel air filter,so please advise what is the next step i should do? Link to post Share on other sites
pops 1 Posted November 2, 2009 Report Share Posted November 2, 2009 i guess go to C2 , they had good results on GVK`s car Link to post Share on other sites
rodney 17 Posted November 2, 2009 Report Share Posted November 2, 2009 rolling road remap...if not already.. then tubo or supercharger Link to post Share on other sites
Jamesr_VR6 0 Posted November 2, 2009 Report Share Posted November 2, 2009 Any chip will simply overfuel your car and make it run rich, a chip cannot alter the ecu software, it acts as a transistor and stops the engine running as it shouldas above get a remap, they are more expensive but they correctly alter the ecu software correctly and safely, u get better gains, better service, and it wont trash your engine Link to post Share on other sites
gsracing 0 Posted November 3, 2009 Report Share Posted November 3, 2009 Jamesr_VR6please dont advise on this subject if thats what you think.an ecu is a computer,the chip is the bit the information is on.so....you swap the chip from the standard settings to a chip with a revised map on it.you are thinking of the resistor mods commonly put on ebay,these are NOT chips for an ecu.a remap simply modifies the information on an ecu's chip (or uses a secondary daughter board to get the same result),the main difference between a chipped ecu and a remap is that a chip is more a more general estimate for a given situation whereas a remap is suited for a specific car,thus giving better performance,but usually for a premium. Link to post Share on other sites
Jamesr_VR6 0 Posted November 3, 2009 Report Share Posted November 3, 2009 Fair enoughBut what your essentially saying is a "chip" is a universal tool mated into an ECU Whereas the Remap is tailored to a specific vehicleengineChips are a marmite thing i guess.either love em or hate em,...personally after i blew the head off my renault megane sprot alize i hate them!!!!It all depends what your after i guess, you pay for what you get!!! Link to post Share on other sites
matty.vrt 120 Posted November 3, 2009 Report Share Posted November 3, 2009 A re-map and a chip are essentialy the same thing on a vr6 as you cannot flash tune the ecu like more modern cars such as mk4-mk5's so your left with the option of buying a generic chip with a pe programed map on it, or getting a custom map made for your specific car then loaded on to a chip. bottom line is either option involves taking a chip out of your ecu and fitting a new one Link to post Share on other sites
Jamesr_VR6 0 Posted November 3, 2009 Report Share Posted November 3, 2009 Thats fair enough, i mean im not making any "claims" as such between the two options, merely pointing out the benefits between the two.If you buy a chip off the tinternet you loose the personal touch, service, and re-assurance of what your buying, plus its not "Specific" to your vehicle, you plug it in turn the key and hope it gives you the gains it states on the box.Whereas a remap is a personal service, down in person by a trained mechanic, albeit a chip in the VR scenario its still a personal warrantied service tailored to your vehicle. you generally get to whack it on a rolling road and see the gains, the mechanic can modify the software to sort your vehicle and the other mods on it.Im by no means trying to prove/disprove what gsracing pointed out about my confusion between the chip and transistor modbut it still boils down to waht you pay for is what you get Link to post Share on other sites
rodney 17 Posted November 3, 2009 Report Share Posted November 3, 2009 correct on all fronts there fellas... the re-map better suits the VR6. The map is done on rollling roads so you also ensure that all areas operate effectively.There are and I am not naming anyone... chips that are cheap and simply alter fueling for example... or more easily described as increase the turbo boost from the safe .8 bar to maybe 1 bar which will kill that tubi/engine in no time..So getting a chip which is a good chip is another thing..The remap is more expensive but it is the way forwards for these cars... as you are not masking knock sensors etc etc for example... and actually dealing with what the car has present in its' set up/modifications.Yes you do have to flash the chip once the programme (map) is sorted, the remap also allows functionality of other ares to remain. An example being the imobilizer but the more complex/or modern the car the more they can benifit from the remap.That said we do approach the C2s of the world for their help with the code breaking on the first time we do something needs.. an obvious example of a higher end programer.. Link to post Share on other sites
Jamesr_VR6 0 Posted November 3, 2009 Report Share Posted November 3, 2009 At the end of the day im glad i bought that chip and blew my meganes engineup.....otherwise id of never migrated to the dark side..... Link to post Share on other sites
