Guest darrell Posted December 2, 2004 Report Share Posted December 2, 2004 HELP!!!! I have vehicle with a 2001 VR6 engine fitted. The ignition is via individual coil packs that are attached to the top of each spark plug. They look and feel fragile. How do I remove them to change plugs without causing damage? I have been on to VW main dealer who has not been helpful. They dont sell a specialist tool and say they havent ever changed plugs in the VR6 engine of this type as fitted to Sharan, Alhambra and Galaxy, which I find hard to believe.Please help someone asap, am supposed to be driving to spain on tuesday!! Cheers dazza &| &| Link to post Share on other sites
binliner 0 Posted December 2, 2004 Report Share Posted December 2, 2004 got any pics? Link to post Share on other sites
Guest darrell Posted December 2, 2004 Report Share Posted December 2, 2004 sorry no pics. but engine is the vw vr6 as fitted to the ford galaxy 2001 model with tiptronic box, etc, manafactured in germany 2001 and sold in italy 2002. Does anyone have any knowledge, its obviously different ignition set up to the earlier golf etc vr6 engine Link to post Share on other sites
binliner 0 Posted December 2, 2004 Report Share Posted December 2, 2004 not something Ive seen before... most of the VRs on here are the earlier 12v models but someone may be able to help. If you havent already done so might be worth posting on www.clubgti.com as well Link to post Share on other sites
Guest darrell Posted December 2, 2004 Report Share Posted December 2, 2004 To help, there are no HT leads, just hard wired to individual coil packs. Ford have been no help either, I phoned pretending to be my local garage asking for advice and they said do rest of service and forget about plugs as they last 40 to 50,ooo miles!!!! Link to post Share on other sites
Guest darrell Posted December 2, 2004 Report Share Posted December 2, 2004 thanks for help so far, cheers Link to post Share on other sites
VR6Pete 1,455 Posted December 3, 2004 Report Share Posted December 3, 2004 I'd be interesting in seeing some pictures of ur lump! Link to post Share on other sites
Nerih 0 Posted December 3, 2004 Report Share Posted December 3, 2004 me too, a ford galaxy lump is 24v right? Link to post Share on other sites
Seademon 0 Posted December 6, 2004 Report Share Posted December 6, 2004 Hi guys! My car has a misfire between 2-3k Rpm and when I turn right for some reason if Im accelerating around roundabouts etc - Its really annoying on motorways because if Im cruising in any gear between 2-3k Rpm the car starts juddering and I lose power - I have to take it out of gear, rev it and then its ok & it might not happen for a while. It sounds like its something silly & electrical! Coil pack? Link to post Share on other sites
shail 0 Posted December 6, 2004 Report Share Posted December 6, 2004 I found this thread - sounds like the same engine? si/non?http://forums.vwvortex.com/zerothread?id=747366Read it, the following text is from there:...If you want to pull these suckers out, remove the wiring harness with the little clip (just use your fingers to squeeze the top of the clip thingy open and pull - POP!) ...and then pull up on the coilpacks. If they've been in there a while you can rotate them a little to get them loose and then pull them straight out, they will come. They fit onto the spark plugs pretty much the same way that your old HT leads used to. Just a snap-on dealy. Link to post Share on other sites
