Jonnyboy82 0 Posted October 10, 2009 Report Share Posted October 10, 2009 I need a new one of these im pretty sure it is the abs sensor? And this im not sure what its called as i need one of these too. Its the tooth kinda disc thing.Also do you know the part number for the one above. Link to post Share on other sites
cabrioman 6 Posted October 10, 2009 Report Share Posted October 10, 2009 top one is an ABS wheel speed sensor and the ring is the exciter ring for the sensor .... Link to post Share on other sites
thegoth 5 Posted October 10, 2009 Report Share Posted October 10, 2009 yep I'd say that's an abs sensor. it has a VW part number on it but I can't make it out from the photo: 3x3 digits and maybe a letter.the disc is an abs rotor, no idea of part #. Link to post Share on other sites
Saunders82 0 Posted October 10, 2009 Report Share Posted October 10, 2009 i havent got the part numbers but.. that abs ring comes as part off a hub flange you wont be able to get it seperate Link to post Share on other sites
cabrioman 6 Posted October 10, 2009 Report Share Posted October 10, 2009 im pretty sure u can get it seperate mate ask at vw as its only held on by a few screws Link to post Share on other sites
craggsy 91 Posted October 10, 2009 Report Share Posted October 10, 2009 Factor in a new front wheel bearing as well Link to post Share on other sites
Jonnyboy82 0 Posted October 10, 2009 Author Report Share Posted October 10, 2009 OK thanks. So the first one is an abs sensor and the second is called an exiter ring? I just need to know so i know what to order or hopefully someone on here is braking a vr6 with these parts :^)And also im guessing craggsy that i will need a new wheel bearing as once i replace the exiter ring the wheel bearing will need replacing as they never seem to come out in one piece. Link to post Share on other sites
Rikki 2 Posted October 10, 2009 Report Share Posted October 10, 2009 Think the abs ring come with a hub only too mate! Link to post Share on other sites
Jonnyboy82 0 Posted October 11, 2009 Author Report Share Posted October 11, 2009 So will an abs ring and sensor from the o/s fit or does it have to come from the n/s? Its just there's plenty of vr6's breaking someone must have these bits. Obviously i will get a new wheel bearing though.And also does it have to be from a car thats the same year as mine? Link to post Share on other sites
