vr6turbo 27 Posted August 30, 2009 Report Share Posted August 30, 2009 after running my car for many years with an intercooler i got sick of saxos and other carswanting to race me. i decided to go stealth and fit a charge coolerthe problems have been keeping the water cool in the system even though i have a 20 ltr tank in the boot a track day ended in very high engine temperatures where i had to stop every few lapsso i have made a custom charge cool radiator up from a cinquicento radiator and 2 x 7inch fans£20 rad£17 each for the fans£15 for silicon hoses£10 for wiring switch and relayplus digital temp sensor £25so £87 all in i plan to have a digital intake temp readout in the dash somewhere and a switch to control the fans on the charge cooler radheres some pictures http://i457.photobucket.com/albums/qq295/scrimpop/vr6turbo008.jpghttp://i457.photobucket.com/albums/qq295/scrimpop/vr6turbo009.jpgit will be a 3-4 weeks before i get the car back together so i will let you know how i get on Link to post Share on other sites
FishWick 21 Posted September 3, 2009 Report Share Posted September 3, 2009 Nice!How long has your VR been turboed mate? I take it the IC was external and easily visible then?Mine's been a daily VRT for 2.5 years with a discrete chargecooler and it's been great. Water is brilliant for absorbing heat and I get very stable and low intake temps.I'd say if your 20 Litres is getting hot, it's definitely a radiator issue. Mine is 20" x 1" x 6" and the water in the tank (boot mounted) is always cool.I'm also going to use a VR Air con radiator as an additional radiator when I get round to it, which should be awesome!Keep us posted! Link to post Share on other sites
vr6turbo 27 Posted September 5, 2009 Author Report Share Posted September 5, 2009 Iva had the vr turbod for about 6 years its been on and off the road a few times due to engine failurelead foot syndrome, started with SPA kit from brasil6psi no intercoolerthen moved on to an eip kit and made up an intercooler,i sold all my old stuff to jim potteri have seen your thread from the beginning to end so know how much effort you have put inmore respect for people who have done all their mods themselves,you are right the radiator for the charge cooler is too small so i hope the cinquicento one works, i also got a digital temp meter so i can keep an eye on intake temperatures form the dash,http://www.evolution-r.com/charge%20temp.html saves setting vag com up to monitor them.i had a look at the aircon radiator and feel the pipe diameters could be a little resrictive when it comes to water flowmatt at c2 has an air con rad i took it off yesterday and its not in bad condition, could do with a paint Link to post Share on other sites
FishWick 21 Posted September 7, 2009 Report Share Posted September 7, 2009 That's a fair while then, good stuff. Yep, expensive and hassle, but worth it in the long run. I have no interest in cars that don't keep me occupied and have no tuning potential. Yeah I considered that too regarding the AC rad being restrictive, but I managed to score a brand new rad from VW for £75, so rude not to try it. I think it will do a reasonable job.I would really like details of your Cinquicento rad though, in case the AC one doesn't work out!I have a little display on the dash that tells me everything the ECU is reading and controlling which is very handy. Saves having a laptop on the passenger seat and driving down ditches reading it.... Link to post Share on other sites
technoveer6 0 Posted September 7, 2009 Report Share Posted September 7, 2009 Kev,Where would you mount the AC radiator? Is there space in front of the water radiator? Is it a Golf VR6 one, cos it's pretty big?Good to have fresh ideas on keeping a running VRT cool.Kong Link to post Share on other sites
FishWick 21 Posted September 7, 2009 Report Share Posted September 7, 2009 Hey KongNo it's a Corrado specific VR6 A/C radiator and the cross member panel has mountings for it in front of the main engine radiator. It's a very tight fit, even as a factory install. Only a few mm clearance between the two radiators and the slam panel.The water channels in the AC rad I've got are roughly the same size as the ones in the Setrab cooler Schimmel sells with his Air - water setup, but the inlet and out hoses are smaller. But the main benefit will be keeping intake temps cool in traffic because it will get cooled by the fans. Link to post Share on other sites
john555 0 Posted September 7, 2009 Report Share Posted September 7, 2009 sorry to hijack your post but im just wondering if yous think this will work i have my cooler setup with allard charge cooler, range rover rad and water pump and a 2 ltr water tank but i still have a spared rad off a bike and water pump off a subaru legacy would i be better just having one rad and pump into the coolertwo rads one pump and cooleror one pump rad and thecooler in one circuit and adding the extra pump and rad into a seperate circuit into the tank Link to post Share on other sites
vr6turbo 27 Posted September 11, 2009 Author Report Share Posted September 11, 2009 not sure till i see some picsi am suprised you can fit a range rover rad infront of the vr onehere an update on the charge cooler rad so farsome pics for your perusal Link to post Share on other sites
vr6turbo 27 Posted September 11, 2009 Author Report Share Posted September 11, 2009 and some more of the re rebuild Link to post Share on other sites
john555 0 Posted September 11, 2009 Report Share Posted September 11, 2009 sory i didnt mean a range rovers actual radiator i ment the ones that you get on a range rover sport for there charge cooler setup like the one below Link to post Share on other sites
vr6turbo 27 Posted September 11, 2009 Author Report Share Posted September 11, 2009 that looks sweet sweet sweeti like the intake come charge cooler and its shineyi found a few on line allready made up in the good old US of Ahttp://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=ZX476765F&zmam=73771597&zmas=4&zmac=60&zmap=ZX476765Fthey seem very reasonable considering i put mine together this for £82i would like the fans to come on when the intake temps reach 50 and go off at 40 Link to post Share on other sites
john555 0 Posted September 11, 2009 Report Share Posted September 11, 2009 im a bit worried that it might suffer from heat soak off sitting on the rocker cover thats why im trying to cool the water as much as possible, that why im considering running two water circuits one with the charge cooler and another just with the water tanki like your idea of adding a gauge to keep an eye on the water tempcheers john Link to post Share on other sites
vr6turbo 27 Posted September 13, 2009 Author Report Share Posted September 13, 2009 heres how i have my system set upyou wont have so much of a problem with heat running a supercharger Link to post Share on other sites
Antihero1981 8 Posted September 13, 2009 Report Share Posted September 13, 2009 i would put tank in boot and nothing less than 5ltrs....run pipes under car Link to post Share on other sites
vr6turbo 27 Posted September 13, 2009 Author Report Share Posted September 13, 2009 add antifreeze to the coolant for the winter Link to post Share on other sites
john555 0 Posted September 13, 2009 Report Share Posted September 13, 2009 i bought water wetter its like anti freeze but keeps it cooler wont be usin 5ltrs thou probly 2 ltr tank plus there will b 1 in the rad another in the lines and aound 1.5 in the coolercheers john Link to post Share on other sites
Phat VR6 3 Posted September 13, 2009 Report Share Posted September 13, 2009 i like your awic intake john. what does everyone think of these kind of setups compared to the sri and separate charge coolers. Will it cool just as well or better? you have runner compensation with johns and nice sized runners will it still do the job of been a pendum (dunno how to spell it lol) even though its filled with a awic?how much power do you make at what psi Link to post Share on other sites
john555 0 Posted September 14, 2009 Report Share Posted September 14, 2009 id like to know this to lol, the only reason i bought it was becasue i wanted to go stage three with my vf charger and didnt want to loose any boost through pipe work of a intercooler but iv sold that now anywayshavent had my car running with it on yet goin to be trying to run 18psi with a rotrex Link to post Share on other sites
vr6turbo 27 Posted September 14, 2009 Author Report Share Posted September 14, 2009 awesome :-d how many bhp will that give you? Link to post Share on other sites
john555 0 Posted September 14, 2009 Report Share Posted September 14, 2009 not sure realy theres a lad making 430 with this charger and pully on a 2.9 corrado engine with cams so im hoping for around 400ish but not realy sure Link to post Share on other sites
FishWick 21 Posted September 15, 2009 Report Share Posted September 15, 2009 i like your awic intake john. what does everyone think of these kind of setups compared to the sri and separate charge coolers. Will it cool just as well or better? you have runner compensation with johns and nice sized runners will it still do the job of been a pendum (dunno how to spell it lol) even though its filled with a awic?how much power do you make at what psi I can't see the Pic of John's but I've seen a stock VR6 intake with a built in chargecooler core. Is that what we're discussing? It was in a PVW or something last year, a black MK3 VRT made by an American firm called something 'industries'? Can't remember the first bit, LOL!It looked brilliant but I'm not sure how much heat would get sucked out of the head by the intake like a wick? It must work though as Jaguar and Mercedes use very similar systems. It will be interesting to see what the intake temps are like as I'd love to use something like that :-) Link to post Share on other sites
john555 0 Posted September 15, 2009 Report Share Posted September 15, 2009 yer its the same as the american blokes just doesnt look as fancy im thinking about getting one of the polymer gasket things that go between the lower intake manifold and head as im guessing that will help abit but ill get it mapped and stuff first then see what sort of intake temps i get so i can see what works and what doesntid like the style more if my vr was turboed honist as there would be hardly any pipe work required so look super clean but im still happy with it here a better pic of itits pretty close to the bonet when shut lke Link to post Share on other sites
FishWick 21 Posted September 15, 2009 Report Share Posted September 15, 2009 I can't see any pics hosed on Photobucket mate, my work block them!! I'll have a look later at home. Sounds interesting though.Yeah with a turbo it would be a really, really short boost path. Throttle response will be awesome. It just concerns me though a chargecooler being sat between a glowing turbo and a cylinder head roasting away at 150+ deg C externally, but as you say, it's good to experiment with these things!I've had an infrared thermometer on my engine and there's some pretty scary temps going on in there!You'll be fine with an S/C though, lower temps coming out of the compressor. Link to post Share on other sites
john555 0 Posted September 15, 2009 Report Share Posted September 15, 2009 yer it would be a realy short path im not sure how hot it would get. the other thing is my cooler is after the throtle body will that make any differencecant wait to get things started so i can see how things realy work Link to post Share on other sites
Phat VR6 3 Posted September 15, 2009 Report Share Posted September 15, 2009 that's why i like it. seems to make sence in so many ways. Ive seen people use the oil breather to top up the oil, might not need it but you could get rid of the oil filler and make it a few inchs wider I see you concern kev. are you saying on a long trip it might start to heat the water though heat soak? never though of that.what do you think about the pendum (what im calling it now lol) is filled buy the charge cooler Link to post Share on other sites
