Slim 0 Posted November 15, 2004 Report Share Posted November 15, 2004 Mine are totally seized and I can't get my old plate off to get my new German one on. I've tried soaking them in WD40, all sorts of screwdrivers, even taken the trim from inside the bootlid off and tried to prise off the bits on the inside of the tailgate and nothing. The only option seems to be to drill the heads off the screws to get the plate off then grind the rest of the screw so it's flush with the tailgate so I can get my new plate on with adhesive pads.Is there anything I've missed or an easier way of doing it? Link to post Share on other sites
Geastb 0 Posted November 15, 2004 Report Share Posted November 15, 2004 I've got the same problem with my tailgate lock - i want to fit my cult society conceled lock but can't get the old screws out.Have you tried an impact driver? They usually shift most things? Link to post Share on other sites
Eat this 2 Posted November 15, 2004 Report Share Posted November 15, 2004 get a junior hacksaw blade cut i flat bladed bit in the head and get a decent size flat blade screw driver whilst hittin it gently with a hammer mine had private plates when i bought it and they were seized on [ Edited Mon Nov 15 2004, 11:05AM ] Link to post Share on other sites
binliner 0 Posted November 15, 2004 Report Share Posted November 15, 2004 I had the same problem with my plinth... in the end I cut the old plinth of and then undid the offending screw with mole grips Link to post Share on other sites
kev-morris 0 Posted January 31, 2005 Report Share Posted January 31, 2005 i drilled the heads off mine, then stuck the new german plate on with pads from halfords Link to post Share on other sites
acf8181 0 Posted February 1, 2005 Report Share Posted February 1, 2005 if you done need the current plates just snap the plate off and chisel it out form the bolt...then the bolt will prob undo with a pliers on it.if you need the plates take kev's advice. Link to post Share on other sites
cliveyp 0 Posted February 1, 2005 Report Share Posted February 1, 2005 i drilled mine out completely then used a shallow headed bolt and nut to hold the plate surrounds on. Only one was siezed, the other just free'd up! Link to post Share on other sites
Slim 0 Posted February 1, 2005 Author Report Share Posted February 1, 2005 I ended up drilling the f*ckers out and filling the hole up with silicone. Used 2 packs of them pads from Halfords to put my plate holder in so I can easily change plates over if the filth don't like my German ones. Link to post Share on other sites
