Jonnyboy82 0 Posted December 28, 2008 Report Share Posted December 28, 2008 Woke up this morning went out got into my vr6 ready to hit the sales and guess what it wouldn't start.It turns over fine with absolutely no hesitation at all? battery is fine so what the fuck could it be?Its never done this before at all and i was using it the day before so its not like its been sitting for a while?Please Help :@ Link to post Share on other sites
JimGTI 0 Posted December 28, 2008 Report Share Posted December 28, 2008 check the three basics, fuel, air and spark for your starters. Much easier to work out whats wrong when you know which system you need to check Link to post Share on other sites
Jonnyboy82 0 Posted December 28, 2008 Author Report Share Posted December 28, 2008 Im no mechanic mate where do i start? *-) Link to post Share on other sites
rodney 17 Posted December 28, 2008 Report Share Posted December 28, 2008 join the AA... Ok so basics... 1 Pop a plug out.. and turn over for a second or 2 tops. can you smell fuel out of the plug hole???2 With a pair of insulated (this is important) pliers or the likes. Pop the plug into the HT lead you pulled off. Turn the engine over whilst holding the plug against the engine block. you should see a strong physical spark. Again only turn over for a second or two..if you are missing either of these then there you go... give us a shout Link to post Share on other sites
Jonnyboy82 0 Posted December 28, 2008 Author Report Share Posted December 28, 2008 I am a member of the aa but i dont have home start :@ i was considering towing my car round to my girlfriends then calling them out? Link to post Share on other sites
DaveVR6'S' 0 Posted December 28, 2008 Report Share Posted December 28, 2008 this happened to me. what it ended to be was that one of the wires in the maf sensor had snapped. checked the sensor plug is on correctly or check the wires. hope this helps Link to post Share on other sites
Guest Nero1701 Posted December 28, 2008 Report Share Posted December 28, 2008 i had a audia3 with all sorts of issues,drove it to the nearest suermarket and called rac!!!ht lead had worked loose from the coil pack Link to post Share on other sites
gavinvr6 0 Posted December 28, 2008 Report Share Posted December 28, 2008 i had similar problem and the earth strap from under the thermostat housing had worked loose Link to post Share on other sites
Jonnyboy82 0 Posted December 29, 2008 Author Report Share Posted December 29, 2008 Ok will try these once i have recovered, been stuck in bed for 3 days with the flu. +o( Thanks for all your help everyone. Link to post Share on other sites
Jonnyboy82 0 Posted January 6, 2009 Author Report Share Posted January 6, 2009 Came across this whilst trying to figure out the problem:Does anybody happen to know what this is and how much a new one is? Link to post Share on other sites
Jonnyboy82 0 Posted January 6, 2009 Author Report Share Posted January 6, 2009 Also ive been told it could be the fuel pump relay? What number is this relay and would i hear the fuel pump buzzing when i turn the key to confirm whether it is this or not? Link to post Share on other sites
Jonnyboy82 0 Posted January 7, 2009 Author Report Share Posted January 7, 2009 Just went to the vw main dealership to get this part and it turns out they don't sell it on its own you have to buy it as part of a set which is about £95 including vat.There's no way im going to pay this does anyone happen to know what my options are or some where i might find one? Link to post Share on other sites
Jonnyboy82 0 Posted January 8, 2009 Author Report Share Posted January 8, 2009 Bump Link to post Share on other sites
ip 0 Posted January 9, 2009 Report Share Posted January 9, 2009 ebay:http://cgi.ebay.co.uk/VW-VR6-ENGINE-INLET-NON-RETURN-VALVE-GOLF-CORRADO_W0QQitemZ130246696533QQihZ003QQcategoryZ9889QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262ip Link to post Share on other sites
Jonnyboy82 0 Posted January 12, 2009 Author Report Share Posted January 12, 2009 Been out there today with a friend who's a mechanic and I can confirm I am definitely getting a spark but it looks like no fuel. I have changed the fuel pump relay today also which made no difference. So could it be the fuel pump? If so where is the fuel pump located?I managed to get the crank case breather valve from ford too which saved me a fortune, cost me £29. Thanks craggsy I am thinking of towing the car to my girlfriends and calling the aa out unless anybody has any other suggestions. This is really doing my head in now the vr6 has been sat on my drive for nearly 3 weeks and im itching to get back in the driving seat.Please some body help :@ Link to post Share on other sites
VDub_Steve 1 Posted January 12, 2009 Report Share Posted January 12, 2009 as far as i know the fuel pump is located under the carpet in the boot Link to post Share on other sites
craggsy 91 Posted January 12, 2009 Report Share Posted January 12, 2009 Been out there today with a friend who's a mechanic and I can confirm I am definitely getting a spark but it looks like no fuel. I have changed the fuel pump relay today also which made no difference. So could it be the fuel pump? If so where is the fuel pump located?I managed to get the crank case breather valve from ford too which saved me a fortune' date=' cost me £29. Thanks craggsy I am thinking of towing the car to my girlfriends and calling the aa out unless anybody has any other suggestions. This is really doing my head in now the vr6 has been sat on my drive for nearly 3 weeks and im itching to get back in the driving seat.Please some body help :@ [/quote']No worries matey....here to help Link to post Share on other sites
Jonnyboy82 0 Posted January 12, 2009 Author Report Share Posted January 12, 2009 Anyone - someone? Link to post Share on other sites
Jonnyboy82 0 Posted January 14, 2009 Author Report Share Posted January 14, 2009 Been at it again today located the fuel pump (thanks vbub_steve) and had the power meter on it theres definately no power going to it so im now totally frustrated with this? What next? Link to post Share on other sites
ingham 5 Posted January 14, 2009 Report Share Posted January 14, 2009 this may help to test if its the immobiliser : disconnecting the battery for 15 mins to reset ecu, as if its your immobiliser it should start only once ,but when its stops it wont start again till immobiliser is reset, Link to post Share on other sites
Jonnyboy82 0 Posted January 14, 2009 Author Report Share Posted January 14, 2009 Funny you should say that as by trying to start it over a few days i have flattened the battery so i have taken it off and charged it over night but it still does not start at all so i guess in a way i have done what you said?Also i noticed that when i re connected the battery the alarm didnt sound or go off where as it usually does or it did with my mk3 gti?Is this anything or am i just pissing in the wind? Link to post Share on other sites
ip 0 Posted January 14, 2009 Report Share Posted January 14, 2009 Okay, so the fuel pump relay is okay but the fuel pump ain't getting power. So either the fuel pump relay is not being triggered or the wiring between the relay and the pump is buggered. You have checked the fuel pump fuse right?Assuming the fuse is okay, get a long length of wire (speaker wire would do) and run it from the battery to the fuel pump directly. Get power on the fuel pump and see if it runs. If not, fuel pump is monged. If it does run, try starting the car.Cheers,ip Link to post Share on other sites
Jonnyboy82 0 Posted January 14, 2009 Author Report Share Posted January 14, 2009 Hello mate hows it going im still loving the coilies Yes i have checked the fuel pump fuse its fine as for the speaker wire thing i'll give that a go.Ive got sparkz off the forum coming down tommorow so fingers crossed he will get it sorted. Link to post Share on other sites
sparkz 0 Posted January 16, 2009 Report Share Posted January 16, 2009 Sorted!! Another happy customer! Link to post Share on other sites
