VR_6 0 Posted November 28, 2008 Report Share Posted November 28, 2008 hi im going to look at a GOLF MK4 1.9 GT TDI 150 2002 100k mileage tmr,any tips on what to look out for or common problems?thanks Link to post Share on other sites
Lizard Racing 0 Posted November 28, 2008 Report Share Posted November 28, 2008 Tappets shatter on these. The ones to go for are the gttdi 130s. Link to post Share on other sites
patpong_pete 0 Posted November 28, 2008 Report Share Posted November 28, 2008 i thought the engine is the same just a bigger turboon the 150 i would go for the 130 as slightly cheaperand can still put revo chip to add 40 + bhplet us know how u get on as i thinking of the GT TDI 130 Link to post Share on other sites
cabrioman 6 Posted November 28, 2008 Report Share Posted November 28, 2008 check when cam belt was done, and general stuff like that, center box brackets break all the time chak that, to fix ur lookin around £100 from wot i remember ... err apart from that good motors Link to post Share on other sites
Charged VR 0 Posted November 29, 2008 Report Share Posted November 29, 2008 Check the usual MK4 stuff like1)Broken rear springs at the bottom of the pig tail2)Craking/Creaking Anti roll bar bushes3)Faulty Cooling Fans!!! Put the A/C on and the fans should run constantly on slow speed, If the pulse on & off fast speed then new fans are needed and they are £££. (Only 150's not 130)4)Clicking from Glovebox can be faulty heater positiong motor. Pain in the arse to do5)Check the carpets for water as front door carriers can leak6)History on window lifter replacement as common failure7) Worn Camshafts and broken tappets (The noise is reaaly bad when these have gone) Link to post Share on other sites
