GOLF MK4 1.9 GT TDI 150 buying advise
Check the usual MK4 stuff like
1)Broken rear springs at the bottom of the pig tail
2)Craking/Creaking Anti roll bar bushes
3)Faulty Cooling Fans!!! Put the A/C on and the fans should run constantly on slow speed, If the pulse on & off fast speed then new fans are needed and they are £££. (Only 150's not 130)
4)Clicking from Glovebox can be faulty heater positiong motor. Pain in the arse to do
5)Check the carpets for water as front door carriers can leak
6)History on window lifter replacement as common failure
7) Worn Camshafts and broken tappets (The noise is reaaly bad when these have gone)
