Phat VR6 3 Posted May 7, 2008 Report Share Posted May 7, 2008 Non, nothink, fuak all brake pressure despite bleeding. Pedal goes strate to floor and has no action on the brakes.Anyone got any ideas as this realy confusing me... Can't think how to fix it Cheers Tom Link to post Share on other sites
SankysVR6 1 Posted May 7, 2008 Report Share Posted May 7, 2008 Sound like the master cylinder, have you done a brake fluid change recently or something. Link to post Share on other sites
Phat VR6 3 Posted May 7, 2008 Author Report Share Posted May 7, 2008 lol Well ive changed everythink.. All the calipers and most of the brake lines but the master cylinder was perfix before.. It hasn't gone vague. Just doesn't work full stop, as in full brake aplyed and you can still spin the wheel by hand.Can master cylinders go like this? Thanks for the reply Link to post Share on other sites
Devildub_06 0 Posted May 7, 2008 Report Share Posted May 7, 2008 Just answered your PM, let me know how you get on. Link to post Share on other sites
Phat VR6 3 Posted May 12, 2008 Author Report Share Posted May 12, 2008 New VR master cylinder, Re did all the flaring to check joints. Re bled Still the same.Im guessing that it can be fixed but I have no idea how to.. Can u recomend anyone who can def sort it... Link to post Share on other sites
UnitedMotorsport 55 Posted May 13, 2008 Report Share Posted May 13, 2008 Did you bleed the ABS unit as well as the calipers? Link to post Share on other sites
kadvr6 0 Posted May 13, 2008 Report Share Posted May 13, 2008 if you cant get it fixed?? the whynot servive station can do a pucker job of bleeding the system, they did mine when i fitted the brembo's. it turned out that i could not get enough pressure into the system to bleed the master cylinder properly. i was also using a gunson eazibleed kit. Link to post Share on other sites
Devildub_06 0 Posted May 13, 2008 Report Share Posted May 13, 2008 Bleed ABS unit as per C2's suggestion. What I suggest you try then is some flexible brake line clamps on 3 of the 4 calipers, push the pedal and record any movement (a mate comes in real handy about this time!!). Rotate this clamping procedure to each wheel and record any movement in the unclamped brake line.I should think C2 is right though, ABS units are an air trap. Link to post Share on other sites
Phat VR6 3 Posted May 13, 2008 Author Report Share Posted May 13, 2008 IVE DONE IT lol no abs... like a total nob i had the calipers on the wrong way round so the bleed nipples where facing down apart from this there totaly the same and when i rush i alway make STUPID mistakes like thatI just looked at it and clocked it. So the fuild was was going into the caliper and just coming out the bottem again. Not filling up the caliperall good now and i can go enjoy it now :-d Feel free to abuse me LOL Link to post Share on other sites
bigjak 0 Posted May 13, 2008 Report Share Posted May 13, 2008 Brakes OZ style?? Link to post Share on other sites
ingham 5 Posted May 13, 2008 Report Share Posted May 13, 2008 IVE DONE IT lol no abs... like a total nob i had the calipers on the wrong way round so the bleed nipples where facing down apart from this there totaly the same and when i rush i alway make STUPID mistakes like thatI just looked at it and clocked it. So the fuild was was going into the caliper and just coming out the bottem again. Not filling up the caliperall good now and i can go enjoy it now :-d Feel free to abuse me LOLive seen that done before ,easy to do ...well done for spotting it Link to post Share on other sites
Phat VR6 3 Posted May 13, 2008 Author Report Share Posted May 13, 2008 PMSL... thats a gudun haha Link to post Share on other sites
vr6newcomer 1 Posted May 15, 2008 Report Share Posted May 15, 2008 abuse, abuse , abuse. Link to post Share on other sites
