Ahhh engine is dead!! (loads of NEW pics added 11/03)
Shafted dude, You're quite unlucky aint you
funny how it died all of a sudden ?
sure its the engine?
Yeah you would exspect oil starvation... low oil pressure ect or possible if the wrong tourge setting been used on the bottem end/ not tighted up properly if its been rebuilt.
If when its running if you take the spark plug leads off one by one does the knocking noise goes quiter it will help tell you which one or ones is knocking (as it stops the load on the piston which you've removed the spark plug on),
If the noise doesn't quiten down atall then its probaly not your big ends. tom
took sump off 2nite... found why my car smokes on over run..lol
found 2 oil rings hanging out off the oil pick up pipe!!!
and one bigend has spun... crank looks ok tho..
im going to bodge it .. and fit 2 shells ive got.. this is just until my other 2.9 engine is built should be 2 weeks max..
i know its not the best thing to do.. but i have to take the chance ive got no transport.. and its doing my head in!!!
i'll post sum pics 2moz im not at home so cant... mess tho..lol
pics.. first and second are oil pick up pipe with piston oil rings hanging out of them..
3rd is big end shells which spun.. and bits i pulled out of pick up pipe..!!!
[lightbox=../../e107_files/public/1202343585_2891_FT217146_photo-0019.jpg]1202343585_2891_FT217146_photo-0019_.jpg[/lightbox]
[lightbox=../../e107_files/public/1202343585_2891_FT217146_photo-0020.jpg]1202343585_2891_FT217146_photo-0020_.jpg[/lightbox]
[lightbox=../../e107_files/public/1202343585_2891_FT217146_photo-0026.jpg]1202343585_2891_FT217146_photo-0026_.jpg[/lightbox]
went 2 my engineers 2day.. ordered bits.. stripped my gd 2.8 engine and removed crank to go in my 2.9.. got engine stand..
so all is lookin well.. crank is being polished, block is getting homed out.. new rings .. and shells etc.. minter.. slip it in next weekend..
