R32 & 4motion (Rear brakes)
can any anybody tell me if the rear brakes are the same coz they look the same to me.
i know the front are much bigger as im looking at changing the brakes on the 4motion to the r32 brakes but just wanted to see if the rear`s were the same and should i change them or not if the re the same i will just paint my clipes to match the front in blue.
thanks pete.
the vented disc will stay a lot cooler because of the vent between the 2 discs`
were as a solid disc will get a lot hotter because both brake pads the inside and outside pad are both pressing on the same disc cause more heat on the disc.
hope that makes sense..
