i have the unorthodox pulleys on my car, 3 piece set. the unorthodoxcrank pulley weighs nothing compared to the oem one as it weighs the same as a brick.
my carnk pulley is underdriven which makes it smaller in diameter comapred to oem one which is no good for those with superchargers as you'll get lower boost.
Just guna get the turn2 one with my pistons...
Quote
CNC and lighten aluminum crank pulley for ANY VW VR6 car. This aluminum pulley is more than 5.5 lbs lighter than the heavy OEM (6 lb13.2oz) pulley. The Turn2 pulley will give you 4+ wheel hp, increased throttle response, faster revs and a butter smooth drive train. You will experience the benefits of this upgrade during the first casual drive. There is no second guessing regarding if "it actually works".
The Turn2 pulley is produced on a 7 axis CNC machine, finished in OEM dimensions. Other brands are done on a simple mill. Supercharged car will benefit greatly from this upgrade with no loss in boost!
The second generation pulleys now comes with the pulley "key" pre-installed, for a true bolt on installation.
