faigolfgti 0 Posted September 7, 2004 Report Share Posted September 7, 2004 My mk3 vr6 is using 021-906-258CB ecu,i saw another use ecu with no-021-906-258M,remove from passat vr6 so i plan to buy it to keep as spare and wondering whether can use for my vr6?Hope members in this forum can assist me.Thank You. Link to post Share on other sites
28v6r 0 Posted September 7, 2004 Report Share Posted September 7, 2004 I don't think so... If I'm not mistaken the ECU has to be of the same serial nos as your original as it's designed to operate certain functions in tandem i.e the ICV Valve for instance, has to be paired to the controlling module, ie if it's a later car, it may have a different resistance therefore not operate correctly...Sawwwwwyyyy Link to post Share on other sites
faigolfgti 0 Posted September 8, 2004 Author Report Share Posted September 8, 2004 I think maybe can because both my vr6 and the passat vr6 is obd-1,both using ignition distributor with seperate ignition coil(not the coilpack model),anyway yet to confirm! Link to post Share on other sites
acf8181 0 Posted September 8, 2004 Report Share Posted September 8, 2004 well, theres a reason for the different part no. if they were identical the part no would be the same. Link to post Share on other sites
28v6r 0 Posted September 8, 2004 Report Share Posted September 8, 2004 Thanks ac for the "laymans terms" I guess that's what I was driving at... Link to post Share on other sites
