vibra technics engine mounts who's got em and what they like ?
ive got VT mounts all around, they well worth the money... not bothered with comp ones... might have a front engine mount you can buy phil, no use to me with the mk2 conversion.
go with the VT over VF ones, VF are too harsh.
You can buy direct from VT, and save 10% with you being a premium member.
I have read its best to replace them all at the same time. Because when not then the harder ones take up more stress and therefore wear out quicker. But when al done at the same time then they work better together and therefore last longer...
That seems to make sence. I know the gearbox one give you alot of vibration in the cab but not the stearing collum altho i can imagin that the rear engine mount could cause that, dont think that would be very nice to live with tbf
i have vibra technics fount mount (£150)
the first one was a fast road and it didnt last long at all' date='
so i replaced the inside bit(£75) to race one ,well see how long it lasts....
How did you replace the inside bit?
Did you use something else or get the replacement parts direct from Vibratechnics or a Distributor?
Can this also be done to the other mounts should they wear out, the internals (rubber) can be replaced?
