xyber 1 Posted August 4, 2007 Report Share Posted August 4, 2007 Got my mocal kit coming next week and was wondering where everyone has place the actual cooler? Im thinking behind the passenger side vent in the front bumper, but it would be good to know where you lot have themcheers Link to post Share on other sites
binliner 0 Posted August 4, 2007 Report Share Posted August 4, 2007 This is where mine was on the syncro, you can just see it under the number plate Link to post Share on other sites
Lizard Racing 0 Posted August 16, 2007 Report Share Posted August 16, 2007 Yeah I mounted mine passenger side as you mentioned. Used the mounting bracket to suspend the cooler from the inner wing on one side. Link to post Share on other sites
xyber 1 Posted August 16, 2007 Author Report Share Posted August 16, 2007 I made up a bracket and fitted right behind the passenger side vent in the end, had a nightmare getting the sandwich plate fitted once the heat exchanger was off though Link to post Share on other sites
Ickyketseddie 89 Posted August 17, 2007 Report Share Posted August 17, 2007 Do you mind if I ask where you got yours from and how much it was? Quite fancy one for the mk2. Link to post Share on other sites
xyber 1 Posted August 17, 2007 Author Report Share Posted August 17, 2007 The Phirm....£160 all in, thermostatic sandwich plate, 16 row slim line cooler and all the bits and bobs inc p&p Link to post Share on other sites
Ickyketseddie 89 Posted August 18, 2007 Report Share Posted August 18, 2007 Thanks dude. Link to post Share on other sites
Lizard Racing 0 Posted August 18, 2007 Report Share Posted August 18, 2007 What oil temps are people seeing with their coolers fitted? Link to post Share on other sites
Radostormvr6 2 Posted August 18, 2007 Report Share Posted August 18, 2007 What oil temps are people seeing with their coolers fitted?Mine never goes over 95 , thats when driven hard. and im charged Link to post Share on other sites
xyber 1 Posted August 19, 2007 Author Report Share Posted August 19, 2007 still running charger in so dont know about when it been given some, but sat in traffic I used to get 94 but now itll get to about 88 then drop to 84 once the thermostat has opened. Did you all delete the heat exchanger? Link to post Share on other sites
Radostormvr6 2 Posted August 19, 2007 Report Share Posted August 19, 2007 still running charger in so dont know about when it been given some' date=' but sat in traffic I used to get 94 but now itll get to about 88 then drop to 84 once the thermostat has opened. Did you all delete the heat exchanger?[/quote']The golf will run cooler, got bigger bay then rado. i kept my exchanger on. Link to post Share on other sites
Lizard Racing 0 Posted August 19, 2007 Report Share Posted August 19, 2007 The reason I asked is because when I was running mine It never went over 66, so I removed it, even when I covered the cooler itself it only went up to 72 which is still to cold! Maybe I had a dodgy thermostatic controller. May try again with a new thermostat. I am likely to see 108+ when I run 20+psi of boost so will need to get something sorted. Link to post Share on other sites
