OIL COOLER POSITIONING
still running charger in so dont know about when it been given some, but sat in traffic I used to get 94 but now itll get to about 88 then drop to 84 once the thermostat has opened. Did you all delete the heat exchanger?
still running charger in so dont know about when it been given some' date=' but sat in traffic I used to get 94 but now itll get to about 88 then drop to 84 once the thermostat has opened. Did you all delete the heat exchanger?
The golf will run cooler, got bigger bay then rado. i kept my exchanger on.
The reason I asked is because when I was running mine It never went over 66, so I removed it, even when I covered the cooler itself it only went up to 72 which is still to cold! Maybe I had a dodgy thermostatic controller. May try again with a new thermostat. I am likely to see 108+ when I run 20+psi of boost so will need to get something sorted.
